Got my Pheer!!!!
Just got my new pheer327 2x72 belt grinder! It is AMAZING! Highly recommended.
After grinding some I have concluded a few thoughts on the grinder. 1-the belt tracks excellently, and is super smooth
2-very quiet and runs with very very little vibration
3-versatile for sure;I can have the flat platen on, then to a contact wheel, or a small wheel(when I finally have the stuff to make those arms). I can use belts that are nearly 82" long and it runs just as good as a 72" belt.( I realize that most of this can be done on other grinders, but the attachments cost nearly as much, if not more than the entire pheer)
4-powerful; I only have a 1hp Baldor and I would never bog it down under heavier than normal use, and if you are willing to put a couple more dollars into it you could get a 2+Hp if you wanted
5-Price: what I paid might not be what you would pay, but no matter what... it was half if not 1/3 of the price of a well known grinder at single speed, and has proven to be well worth the money so far.
6-heavy duty, the frame isn't solid steel,which just seems impractical for a hobbyist/part time knife maker.But by no means is the frame weak or flimsy or fragile.the tubes are fairly thick, and is extremely sturdy and well built.
The only cons to show are that the platen plate that the wheels are connected to seems to get in the way a little, and the tooling arm Doesn't always get completely tightened consistantly.
I will try to post pics, but that hasn't been working when I try so I guess I'll try and figure that out.
Thanks for taking the time to look at this, and if you are looking into getting a grinder... or another grinder, than I would definetely check out some of his grinders
http://www.2x72beltgrinder.com/default.html
Congrats on the grinder. Ive just finished building my NWG but need to hook up the motor and what not, cant wait. No more fighting with the 2x42. I looked at maybe getting the one you got but in the end it was cheaper to build my own as I already had a 1hp motor. Those are still a good deal though.
Vongrats on your grinder!!! I seriously considered the NWG but was afraid I would make it no good, even though I have heard great reviews. Before I bought the pheer I was using a 1x30, and it was sooo hard to get a good even grind. So I bucked up and spent the money and I'm very glad I did.
I ordered a Pheer 3 weeks ago , good time to make a boat load of micarta , clean out my basement , build new bench for grinder , order belts , build an etcher , wait for Shop Vac air cleaner to arrive .Order steel Have I forgot anything ?
