Gotta match?
kgd
I have seen a skill promoted and advocated in many sources including books and video. It was shown to me directly by George Hedgepeth a survival instructor from Michigan. I have also seen it done by Cody Lundin in one of his videos and of course seen it many times done on the forums.
The skill is this. You have 1 paper match left (who the hell carries paper matches in their kit?). You then carefully split the paper match beginning from the bottom of the match and separate it at the sulphur head hence making 2 matches.
I admit its kind of cool to watch, but I also consider it a kind of parlor trick. I submit it to the forums to debate:
If you needed fire and you had just one paper match and striker from the package flap left, would you split the match in two or would you use it as is????
Advantages as I see it:
-you have two kicks at the can in getting your tinder to light
-you can potentially build another fire in the future if you let the current fire you are building go out
Disadvantages as I see it.
-you risk screwing up the split and destroying the integrity of the match when attempting to separate it. This is more likely to occur if the matches are old or have been handled harshly.
-the size of the sulphur head, the chief accelerant for the ignition, is reduced by half. In the best of conditions this may have no effect on the ability to ignite the match. In the worst of conditions, heavy fog/high humidity reducing the size of the sulphur head may contribute to its failure.
My recommendation. I would use the one match as is and spend more time and effort getting really good tinder and kindling. I might even consider collecting punkwood to get an ember going as a failsafe while trying to ignite my tinder. Then again, I have some competence in my ability to perform friction fire if I need to so the one match remaining scenario doesn't seem like an 'end-of-game' decision in terms of ability to make fires into the future.
What would you do?
[The old joke goes something like this:
Person 1 - 'Hey Joe, gotta match?'
Joe - 'Ya, my arse and your face.....']
Well if it was something I practiced and could do it without a problem I would consider splitting the match. As it stands now I would just use the match instead of messing with it. However the point is moot because like you say, who carries paper matches? Heck I don't even carry matches of any kind in my gear. Matches are a waste of space IMO:D
I have done the match splitting thing with success on quite a few occassions. But like you said it was more as a trick.
Like you I am pretty good at friction fire so I have that to fall back on, so if I was in a situation where I needed fire now; that whole match would be getting used.
I would use it as is. I wouldn't risk it in a situation that I needed a fire. If I ruined that match, and had to rely on friction methods, I am not sure that would go too well. Fine motor skills aren't the best under stress, after all.
I've played around with splitting the match and sometimes it works fine and other times it does not. The disadvantages listed in OP are mainly the reasons why it would not be the best idea if this was your last match and you were in some sort of trouble.
So for arguments sake I would use the single match and get a good tinder bundle ready before hand...
But personally, as Shotgun mentioned, I don't care any matches either. Helios, BIC and Firesteel. Plus knowledge on creating a friction fire.
I don't even remember the last time I saw paper matches. Actually, except for in my backpacking/camping gear I don't remember the last time I actually saw any matches.
If I did happen to have one match I would use it as is. Much better to risk being able to start a fire with just one match than risk not having anything at all by busting it.
I would use the match as is considering I have not practiced splitting a match before. That said, I only use matches for lighting propane stoves now and days.
From what I've seen , the quality of wooded matches has went steadily downhill over the last few years , whereas paper book matches are still the same old thing. I find them more reliable actually than the wooden ones provided they are kept dry.
I always rely on the trusty firesteel instead and would never consider splitting a match. I'd rather give it a shot with the whole thing , paper or wood if I had to.
Let me ask you this...
So, you have your stinkin single paper match, it is 45below and you are in the Alaskan woods. On the brink of hypothermia and beginning to lose fine motor skills, you clammer your way to a vacant cabin (yeah, you lucked out... go with it). You open the door to see a woodburning stove, one candle and an oil lamp. You know this may be your only chance cuz Ken isn't with you to save the day with friction fire... which do you light first?
Rick
I'd light the match first :D
Candle. And pray the match works....and have the lantern ready too.:)
Rick
I would light the candle first simply because it would be easiest to light the other two with.
My father and and older brother (seven years older) taught me how to start fires. The first goal was to teach me how to consistently make a "one-match-fire". I have been successful with versions of the bow-drill fire with various materials and continue to practice this. If I only had one match and conditions were dry I would make every effort to go the friction fire rout before even using the match. It it was wet and I needed fire I'd use the whole match and then start making components for friction fire for the next fire.
Rick
Ha ha ha ha. Trick question. You didn't say a wood stove. You said a wood burning stove. So the fire is already lit. You are a sneaky bastard! I'd check to make sure the owner wasn't in the outhouse.
Rick
matches? do people still use matches?
I dont know about you guys but the match would be added to the tinder pile and out comes the road flare!!!! failing that a jet lighter failing that a bic lighter and a box of hexemine, Im gona try splitting the match just for kicks but once youve used a flare for fire its hard to go back to any other means
So why hasn't anybody put matchheads on fatwood sticks, yet... the "Fatch".
That is like my 7th million dollar idea, today. The one just before that was a composting toilet that actually makes chewing noises when you flush.... nom-nom-nom, gulp!
Rick
In compromising weather, I am splitting the match. If you practice it a couple times it is pretty easy to split. If you do mess up in the splitting process it comes in the form of putting too much material on one side.
My rationale goes beyond the match itself functioning properly. I would rather have a second chance for the other variables such as wind, rain, poor/wet tinder/kindling.
How to light a match including the splitting of a paper match...
[youtube]8NJ1PXzzMZo[/youtube]​
Rick
in my sleep addled state I had to read that twice. You Sir, are disturbing. :D That being said, i think that would make a funny childrens show.........:eek:
in a thread about matches , I feel that the old dickhead needs a mention
no joke , used to have a few boxed of dickheads but they all got pinched on me .
http://www.dicksmithfoods.com.au/?d=main&p=matches
nothing special about them , but they did promote care lighting a fire , or youd get laughed at by your mates for being a bit of a ... ahh never mind
