- Jun 12, 2012
Kicking ideas around for a few extra bucks, and made a base for my wicked edge. The one with the sharpener mounted is about 9" square. The blank pictured is about 12" square, +/- a little each way. I also have a couple of more blanks of the same material the sharpener is mounted on, again about 12" square.
Blank will arrive drilled for the Wicked Edge or if you have something else you'd like to mount, I can drill to accommodate, if you can provide a template. Also includes 1" non-skid feet epoxied to the bottom. Corners and edges are eased. There will likely be a small amount of pop out on the bottom side of the blank at the drill sites, but this will not interfere with mounting the sharpener.
I'm asking $50+$15 flat rate shipping (they're heavy!)
