Mark Williams
Moderator
- Nov 28, 2000
Just alternate reaching for the sky with each arm for a few reps with something heavy, like your wallet
You can start off with a light one like mine.
I consider them extremely important. Since bench presses usually involve heavy weight, it's vital that the press is balanced. The weaker cuff will be susceptible to tears because of overload. When you start to do some serious poundage the risk of injury increases. Especially during overhead presses. Frequently, damage is initially started by uneven bench presses. Couple those minor tears with bringing a behind the neck press to low and major damage is likely. Most people will shrug of an uneven press thinking that your dominant arm is naturally stronger. Your grip and rotator cuff are stronger only because they get the most work in your dominant arm. That's why it's important to start with your off arm and count the reps to failure. Once you know the limit of the off arm, doing the same amount and no more with the dominant arm keeps things even. In time both will be become stronger equally. When first starting a weight training program it's best to work the rotator cuffs first thing before every workout.johnniet said:I'm a big fan of rotator cuff exercises (especially #2 there), but is this really a good idea?
Should you really ice the shoulders immediately after exercising? Or is that part just meant for people who are rehabilitating after an injury?
I hear ya. But those rotator muscles are already out of whack. Unless your ambidextrous and regularly use your off arm to hammer, throw, etc. Dumbbells are a more intense workout and somewhat more dangerous. More stabilizer muscles are brought into play with dumbbells and fatigue becomes a factor quicker. Remember, it was you who said grapefruit size.Spark said:See, I'm just doing dumbbell exercises instead of barbell ones becaue I want both sides to develope equally, instead of worrying about my strong side cheating for the weak one. Plus, on dumbbell exercises, you can't bench as much as with a barbell, so the weight is a lot lower.
