This GRAYMAN MEGA POUNDER is designed for field carry, strong enough for hard use. The edge is straight for easy sharpening on the go. The full tang has a lanyard hole and a flat butt that can take a pounding. The Mega Pounders are single bevel (chisel ground), flat ground for max blade strength, made from tough 1095 High Carbon 1/4" thick steel. No frills, just time tested materials and solid design for no-nonsense deployment. Blade is 2"wide x 9" long with overall length of 15" and has a factory "toothy working edge". Included are custom scales comfortably fit for right hand use as well as the original scales and screws. the sheath is equally beefy with a Kydex insert. Can be worn via Velcro belt loop or attached to Molle webbing. I couldn't resist when first getting it and took a few whacks at a green branch. It's otherwise new and unused. selling to fund another purchase.
F&F shipped. Can also do Venmo. More pics on request. Thanks for looking
