- Sep 18, 2022
I'm confused, what role did the knife actually play in dynamite? What's slitting dynamite entail?
As stated before, it probably doesn't translate to 2024 very well. However, it is a cool piece of cutlery history and will be welcomed in more than a few collections.i gotta ask, how much dynamite is one cutting these days to require four sheepsfoot blades?
I’d like to know the real history too. My 70s kid imagination immediately goes to a hypotheticalI'm confused, what role did the knife actually play in dynamite? What's slitting dynamite entail?
From. https://www.bisbeeminingandminerals.com/blasting “Preparing the dynamite, this varies from miner to miner. I personally take each stick and twist it just enough to wrinkle the wrapper breaking up the dynamite inside for tamping. Some miners will roll the stick between both hands to soften the dynamite. Other people take a knife and cut a slit in the wrapper loosening the dynamite inside. This technique is especially useful when loading holes that are overhead or at a steep angle, because it allows very good tamping. Rarely, the wrapper is removed entirely and the dynamite inserted this way. This allows you to put a lot more of the explosive into the hole and gives great tamping. Some miners do nothing at all and just load them right out of the box. Each loaded hole will need to have some type of fuse and blasting cap. Bisbee's underground mine nearly always used fire fuse (safety fuse).“I’d like to know the real history too. My 70s kid imagination immediately goes to a hypothetical
scene of The Lone Ranger slicing the end off of a stick of dynamite with a burning wick to prevent a railroad bridge from blowing…
Excellent!From. https://www.bisbeeminingandminerals.com/blasting “Preparing the dynamite, this varies from miner to miner. I personally take each stick and twist it just enough to wrinkle the wrapper breaking up the dynamite inside for tamping. Some miners will roll the stick between both hands to soften the dynamite. Other people take a knife and cut a slit in the wrapper loosening the dynamite inside. This technique is especially useful when loading holes that are overhead or at a steep angle, because it allows very good tamping. Rarely, the wrapper is removed entirely and the dynamite inserted this way. This allows you to put a lot more of the explosive into the hole and gives great tamping. Some miners do nothing at all and just load them right out of the box. Each loaded hole will need to have some type of fuse and blasting cap. Bisbee's underground mine nearly always used fire fuse (safety fuse).“
Not much- the stuff they use to stabilize and shape dynamite would be hell on steel edges.i gotta ask, how much dynamite is one cutting these days to require four sheepsfoot blades?
Kieselguhr: A porous siliceous earth that was mixed with nitroglycerin to create a paste that could be shaped into rods
Of Course!!!Hmmm… I do handle nitroglycerin often, although I’m a pharmacist. I wonder if I can justify needing one.
Preach it, brother.That’s a damn cool knife.
No Lie!!!That’s a damn cool knife.
