- Feb 1, 2001
I bought a Falcon folder from John Greco at Blade this year and I must say that John is a really nice, layed back guy. The Falcon is a very heavy duty folder with a lock up as tight as a CR Sebenza with absolutly no blade play. The blade is made of 8670 carbon steel which is a european steel used in industry to cut other steels. The knife is exactly the same size as my large Sebenza(sorry I don't have a tape measure with me for exact measurements) and is 3/16 thick. It is a framlock folder and the handle/lock is also made of 8670. As other reviews have stated the first thing you notice about this knife is it is extreamly stiff and at first you will need 2 hands to open and close the knife. After a few days of "break in" it is much easier to use and can be opened/closed with one hand.
One of the first things I noticed was that the blade was rubbing on the liner when you open/closed the knife. I looked at this closer and it was indeed the blade that was not straight. I think it was warped or maybe ground crooked but I really couldn't tell. This really bothered me at first but this is a hard using knife so I tried not to let it bug me to much. I have heard that many Falcons have this problem(warped blade)and I talked to John about this and he said that he was having a few blades warp and he had no control over it as some came out straight and others came out warped??? He is trying to work out the bugs as to why this was happening.
Well I thought to myself I think I can bend this blade back to straight in a vice. So I put the folder in my vice about 1 inch from the tip and applied pressure on the handle where the tang meets the lock. I did not want to grab the handle at the butt because that would probibly break the blade/handle juncture. I put alot of strength on the blade and it flexed quite a bit(I'm guessing maybe 20-30 degrees but I'm probibly off a bit). The blade just kept spring back to true time and time again! I gave it one more try to see if I could get it even a little more straight. I put all my body weight(175 pounds) on the blade as hard as I could and "bounced" on it and then the blade snapped! The 1 inch that was in the vice snapped off. Now I felt pretty dumb as I was not trying to break the knife but just trying to get it straight so it would not rub on the liner. I called John and told him what happened and that it was totaly my fault that the knife broak and that I wanted to buy another one only if it had a straight blade. He said no problem and sent me one(perfectly straight) at no charge as his knives are guaranted no matter what! Only few makers will offer a guarante this good to cover extream abuse!! John said this was the first folder that came back broken and he said He tried to break one in a vice just like I did but was unable to as he said he weighs 135.
Well I must say Greco knives may not win any beauty contests but I will sat they are extreamly strong and and 8670 holds a great edge with the best and the servise is tops!!! If you are looking for a strong folder,maybe the strongest on the market the Greco Falcon might be for you and I know it will never fail you in the field!
