Well, I'll chime in with my reactions as well.
I received my (2)Falcons this past Friday. At this point, I am working with one of them. The other will be placed "in reserve".
All comments about the stiffness were not in the least bit exaggerated. I have been working the pivot since, but have started to
achieve some reasonable success. I have basically used Militec-1 to ease the process along. I used the lubricant in the recommeded way, i.e. heat the joint to the point where it becomes uncomfortable to the touch, then apply Militec and work the joint. This process can be repeated as often as required.
What I have discovered, also, is that all the stiffness does not seem to come from the pivot area, with it's very nice bronze bushings. It also comes from the very tight pressure of the frame lock against the blade itself. This is one really tight sucka'. I'm not sure how much that will break in over time. You need a serious thumb to move it. Also takes two hands to close it.
All things considered, the knife is starting to take it a bit easier on my body and I'm sure easier days are ahead.
That said, the knife gives a tremendous feeling of strength and has a good "feel" in the hand. The blade shape is very useful and the edge was delivered with a beautifully ground, convex final edge. I've only done a little cardboard cutting with so far, but more use is on the way as the action continues to become more "civilized".
Thanks to Mongrel for the heads-up to this really amazing bargain of a knife.
Mongrel, if you make it to the NY Custom Knife Show in Nov., you have a beer or two (or more
) on me. I'll be there for sure.
