Esav Benyamin
MidniteSuperMod
- Apr 6, 2000
Is that Alien Skin?a three dimensional surface texture on my titanium rings
So how much output is there on the ones that can pop balloons and such?
I also got two red ones at 635 and 650 nM and there is a real difference in brightness. Again both were tested for true power output so, 5mW is real power not an advertising boast.
Those appear to be a fantastic deal. Both ones I saw on e-bay are name brands; Rofin Sinar and PRC. I believe that those are for the lasers themselves and don't include the moving table such as a CNC machine table. Tables could be moved with jigs and fixtures by hand if you got clever enough though. The 1350 watt PRC looks exactly like the laser at the heart of the $750,000 laser I used to work on. It has a turbine to jet gasses into the laser chamber at nearly the speed of sound to get more efficiency from the lasing process. It utilizes a U shaped lasing tube so that the actual length of the tube would be something like 15' long. It has an output beam about the size of a quarter that gets focused down to about .015" or so. I would test the mirrors by blasting holes in cardboard or wood before it got focused down. It would blast a charred area into the cardboard instantly, and from the shape and orientation of the burn, you could adjust the copper mirrors. The beam itself is far infrared, so is not visible.
The laser takes bottles of nitrogen, CO2, and helium to work. It also takes a huge amount of electricity. I imagine it takes 460 volt 3 phase at pretty high amperage. The problem with laser like those is if something goes wrong they are seriously expensive to work on. Just the lenses and mirrors are extremely expensive, like hundreds for the lenses and thousands for the mirrors. I would expect to pay something like $75,000 for a used sytem like that, (I looked for one when I bought mine!) so 10K is way down there already.
Percieved brightness, that is, I presume - 5 mW is 5mW at any wavelength, it's just that your "sensors" (eyes) are quite non-linear and non-uniform across the entire visible spectrum.
