BDubbs
- May 25, 2020
The easiest way is to wear your work jeans and drop the knife in and let time & walking do The removal . You could try buffing it our with white compound and the problem is you may damage the scales since you say there is a gap., I’d just carry & use it myself.So wife found me a used 78 in smooth white bone but it looks like the edge of one of the handles along the spring has some polishing compound in the grain? Here’s a photo, any thoughts on how to get it out? Got a bit of a gap going as well it looks like.
Yea, texture there is already a bit rougher, like a previous owner went amateur hour on it. I’ll stew on it a bit and maybe send a photo and email to the mothership to see if I can get it fixed with the gap or replaced.I like what Rino said, I think I'd d ok that but if it really bugged I'd try a dry cloth wheel on a dremel.
Yes, I imagine so. Once it's down in the pores, it's pretty difficult to clean.... although, I'm not an expert on how knife companies "do it".. I know the 62 white bone pocket carvers were about 50/50 on having black flecks in the bone.I’m assuming it’s polishing compound but maybe it’s not. If it was compound it would have been done at the factory...would they have let it go like this?
Looking more closely at the pics, your flecks look a little green, which would also suggest verdigris staining from the brass liners....
There is a chance that this not honing compound but verdigris. Try a weak acid, like apple cider vinegar or lemon juice. Soak a Q-tip and put the wet cotton on one spot and let it work for a couple of hours. If it’s honing compound it’s aluminum oxide suspended in green wax, which may respond to heat. The best solvent for waxes is acetone. You can soak a knife in acetone, but probably wouldn’t do that except on bone or stag. I’d also try a soft brass wire brush.So wife found me a used 78 in smooth white bone but it looks like the edge of one of the handles along the spring has some polishing compound in the grain? Here’s a photo, any thoughts on how to get it out? Got a bit of a gap going as well it looks like.
Dave I still haven’t tried cleaning it, more to follow.So what worked, and didn’t?
