grind angles
Just a quick question I'm hoping someone can help me with. A couple weeks ago I came across a chart that layer out grind angles for different blade thicknesses and how high you want the grind to go. Does anyone have a chart like this or can point me to it?
Thanks.
Good grief! If I needed to know anything on that chart I'd just draw the cross section to scale using AutoCad!:D
Which is cool, if you have AutoCad. :) A flat piece of paper can suffice some times.
Thanks Fred and 1234... Unfortunately, I can't afford several thousand $ for AutoCad, so I printed the chart, sealed it in plastic, and hung it on the wall in the shop. Use it all the time with an angle cube.
Tim
