- Dec 24, 2014
I'm having trouble with my finished grinds. I was wondering if you guys after heat treat use higher grits on your sander, or do you hand finish the grind?
I think I'd rather hand finish as I feel more precise than throwing it back on the grinder but. Say I use an 80 grit to finish off the edge after HT, I'm going to want to sand it from tip to butt, instead of edge to spine. So Would I start out with 80 grit to get rid of the vertical sanding lines? Or start lower?
