Is the ratchet that important? More important than being able to run in reverse?The Northridge is the only one with ratchet tension. Go for the Northeidge
Yes, plus the Northridge will run in reverse. Ratcheting tension is a must on a grinder as far as I'm concerned.Is the ratchet that important? More important than being able to run in reverse?
1. Some folks prefer the ratchet type, while others prefer the metal spring, but with a compression spring. Gas shock - again they do work, but some folks say they don't last long due to dust getting into the shock. I've used all three, and have finally settled on the compressed metal spring.Thanks everyone.
Does anyone have an opinion on the importance of the following?
1. Tensioning mechanism. One has a ratchet, one has a metal spring, one has a gas shock.
2. Running in reverse. Only the Ameribrade runs in reverse.
3. Having 3 tool arm slots. Only the Brodbeck has 3.
Thanks. I just spoke with George and it will indeed run in reverse. They just don't include the switch for liability reasons, but it's not hard to add the switch.Yes, plus the Northridge will run in reverse. Ratcheting tension is a must on a grinder as far as I'm concerned.
I have a Brodbeck and love it, but the only other grinder I've used is a basic KMG, not any of your other choices. That being said, I much prefer my gas shock system over the spring at least on the KMG. Not sure why you couldn't modify that particular feature though.Thanks everyone.
Just because it will run in reverse doesn't been tracking can be adjusted in reverseThanks. I just spoke with George and it will indeed run in reverse. They just don't include the switch for liability reasons, but it's not hard to add the switch.
Are you saying some folks care about whether the spring is compressed vs stretched because it's on the other side of a lever?others prefer the metal spring, but with a compression spring.
Stacy answered nicely, but to expand a bit on the answer. Yes, I'm referring to a compression spring that's located between the tension arm's pivot point and the front of grinder. While I've read some folks to claim the stretch spring that's located behind the pivot point doesn't track as well, I've never understood the difference in location. I prefer the compression located in front of pivot point because that helps keep a smaller footprint. The really important thing in tracking is a very rigid tension arm with no flex, and no slack in the pivot point.Are you saying some folks care about whether the spring is compressed vs stretched because it's on the other side of a lever?
Why would someone concern themselves with this choice? Levers work just fine, right? Does it just add on more point of play in the system?
But it can.Just because it will run in reverse doesn't been tracking can be adjusted in reverseI haven't personally found that I use it much though.
it can be tracked in reverse?But it can.
the Vashti grinder I've got is gas sprung, and it has a gizmo that addresses what you're talking aboutWhat people like about a ratchet is it is quickly and easily set by the user at the tension needed each time you change a belt. A spring or gas shock has one setting without making adjustments to bolts and such.
You can tighten or loosen a ratchet while the grinder is running.
