Grinder frame design.
Yeah 20” wheel was what I wanted to do but there is so little area for an idler/tracking. With a 20” wheel the best way is to have it be the driving wheel.
Something like this one , but with two wheel not like this
You could use a 5 1/2-6" drive wheel with a 20" machine. Use the weight of the motor for tension by hinging it a bit forward of center.
Make the hinge/motor mount swivel for tracking.
As for your 12" wheel, I would just build a standard 1 1/2" tool arm grinder that would accommodate at least a 14" wheel.
I was recently watching this, which I thought was a pretty brilliant idea for tracking a two wheel grinder, which uses the motor and drive wheel as mike-e mentioned above. I'm sure it could be made in a more crude/easier manner if you wanted.
(For what it's worth, I recommend watching the entire 6-part build series, not only for all the clever construction and machining techniques, but because it's just plain fun lol)
Video showing the finished grinder:
Here's the video specifically dealing with building the motor tracking system:
~Paul
My Youtube Channel
... (Some older vids of some of the older knives I made)
My original belt grinder had the motor weight as the tension and when I wound load up the belt the motor wound climb up the belt and slack the belt. Now this was the drive belt of a stepped pulley set up but it was very problematic.
Jt, I think you should make some production grinders ... You not only have all the equipment to do it but you are a very knowledgeable knife maker so you know what works and what doesn't, and what would be innovative...
Yes, like on the BBA20 by Burrking. Excellent solution, and maximizing contact wheel size.
Bruce Bumps 24" machine! I really want a 24" machine as well. Posted about it some time back. I did put an order for one shortly after but the whole deal collapsed since the maker's wheel supplier could not make that size anymore. Since then I did find another supplier but I'm more and more leaning towards a 20" one since I'll be able to use standard belts that goes on my current grinder, but the jury is still out on it..
To run a very large wheel on a standard grinder, just make a longer tool arm and use a longer belt. You will need a 1.5" or 2" tool arm.
