Grinder in a box motor questions..
Go with 1750. You will have sfpm control by deciding on drive wheel size. What is keeping you from pulling the trigger?
I'm going to be building it instages, just to ease the cash flow, so I've got a little while to decide on the motor.
I just want it to be enough for work other than knives, which it will be. I'm making due with what I've got now. Lol
I don't want to usurp this thread, but I too am getting ready to build a GIB and am a little confused. If the op uses a TECO FM50 on a 2HP motor, won't that drop the HP down? It looks like from the user manual the TECO FM50 running on a regular 115v line the max HP output is 1HP. Is speed control more important than HP??? Would running pulleys instead keep the HP the same and just change the rpm?
PT Doc, What you say is true but if you use a 5 inch drive wheel the surface feet per minute will be only 2258 with a 1725 RPM motor and if you can find a custom made 6 inch drive wheel with a 5/8 bore the sfpm would be 2709. By comparison if you use a 3450 RPM motor with a common 4 inch drive wheel it will produce about 3650 sfpm. Lastly the GIB mounting plate is so close to the centerline of the motor that you cannot get an 8 inch wheel on it IF you could buy an 8 inch wheel and the wheel is so close to the mounting plate with wheels larger than four inches it would be a pain to slide belts over the drive wheel. I just finished making a GIB grinder last month and I thought it out for months. I know that there are knife makers out there who would be happy with 2708 sfpm with a 5" drive wheel and a 1725 RPM motor but I would not. My main grinder is a KMG with a custom made 4 3/8 inch drive wheel and a 1725 RPM motor with pulleys to double the speed (and a VFD) and it makes about 3950 sfpm which is just dandy for everything in my opinion. I see that USA Knife maker's sells the Uber grinder designed by Brian Fellhoelter and they recommend the 2 hp 3450 RPM motor. They do not sell motors so it is probably good advice. Larry
I won't be running 115v. My grinder will be 220v powered.
I haven't settled on the Teco as my final choice. I've got a couple months of flip-flopping ahead of me. LOL
If it is direct drive, 3400 rpm motor, without question in my mind. I would rather have more speed and not use it a lot than not have that option. For reference I have a 3hp 3400rpm baldor with a six inch drive wheel on my little buddy grinder. It does not throw sparks, it throws plasma! I dont crank it to full speed all that often but it is there when I want it. Both rpm motors will go slow just fine.
So many good recommendations here. A few things to consider are the MAIN purpose, most likely speed and mounting location.
Are you going to be hogging off lots of steel? Then higher speed and ceramic belts will work great. If not hogging large quantities and more finishing work the slower speeds are more likely. I don't know if Teco is the same Kbac drives with regards to torque, but at half of the top speed, you have half torque. If you overdrive the motor to twice the motor plate speed, you have half the torque. At quarter speed, you will have one quarter of the torque. So you have to decide what range you will want to be in. 2700 sfpm is crazy fast no matter how you slice it. No if you are tring to remove large amounts of steel than it will take longer than a 6000 sfpm setup.
If you are mounting the grinder on the edge of a table or on a riser then any size drive wheel can run so you could theoretically get the desired sfpm with the correct size drive wheel. Do you have capabilities to make your own drive wheel or will you be buying one already made? I know that kmg has 4 and 6" drive wheels, wilmont uses 5". I don't know the size on the bader but they look bigger. I think the tw90 is 6".
Clear as mud? No matter what you choose, you grinder will eat steel.
Clear as mud.. ;)
It'll do service as a general shop grinder.. It's probably major overkill for what I'll be doing, but I think it'll be useful and it'll be fun to build. Right down my alley.
I think I may just go with the 3450 and see what happens. If it doesn't work, I guess I could build another.. ;)
Clear as mud.. ;)
That will work out great. A 4" wheel gives you slightly higher sfpm number than rpm. I think that 6" gives you 54% more sfpm than rpm number. Could be off, going from memory.
Keep us posted.
I am getting deeply confused by all this. Though I normally deal with IEC-frame motors, pretty much all of the general principles seem to apply to 3-phase motors in general.
I concede it is just about possible that you are all talking about 56-frame motors, and that the technicalities of getting a couple of HP out of a motor frame that was originally intended for Fractional Horse Power motors mean that they are wildly different to other, industrial, motors: sticking with the 56 frame size obviously removes the option of going up a frame size when dropping a speed to maintain the motor output. The reason I'll talk about "most" motors is because I do not see enough 56-frame motors with high outputs to know whether they are a special case.
I've been using VFDs on and off since the mid 1980s. The advice given by both motor and VFD suppliers for most of that time has been to use a 4-pole motor and vary the speed between 10 Hz and 100 Hz when the speed turndown range is important.
The mechanical components of (almost) all motors are standardized as far as practicable; the difference between a 2-pole, a 4-pole and a 6-pole motor of the same frame size will just be the windings and these are static. The rotor, bearings and seals will be the same on the 3600 RPM, 1800 RPM and the 1200 RPM variants. If the manufacturer offers variants with higher pole counts, these will also have the same rotating components. It's just the way modern manufacturing works.
This means that the moving parts of an 1800 RPM motor are exactly the same as the moving parts of the 3600 RPM variant and therefore are safe to run at the same speed.
As a general rule, motors tend to be designed to run on both 50 Hz mains supplies and 60 Hz mains supplies, even if the rating plate only mentions one of them. As frequencies get further from the 50-60 Hz design range, losses tend to increase within the motor and efficiency drops. Back in the mid-'80s, the advice was that 10-100 Hz caused no problems, but things tailed off quite rapidly once you left that range. That was close to 30 years ago (ancient history; nobody had a mobile phone!) and things seem to have improved over that time. Certainly I see no problem at all when running a current model industrial 4-pole motor to 120 Hz. I don't actually see a problem when I run at 150 Hz either, but I prefer not to exceed the mechanical design speed of 3600 RPM. So far, I have been unable to find a manufacturers statement that gives a permissible speed in excess of 3600 RPM when run on a VFD (with the exception of 400 Hz, 24000 RPM spindle motors and other specialist stuff).
On basic V/Hz drives, the lowest frequency I am comfortable running is 10 Hz. It does not seem to matter whether I am running a 2-pole or a 4-pole motor, I find that somewhere between 10 Hz and 7 Hz, it starts to feel "coggy". It is enough to affect the finish on my lathe (my normal test-bed when playing with a drive for the first time), but I don't know whether it would be as noticeable on a belt grinder. A V/Hz drive has a fixed (usually) linear relationship between Voltage and Frequency when running below the rated frequency.
In line with the manufacturers claims, I find that "Sensorless Vector" drives provide better low speed performance, running smoothly down to a couple of Hz or less. SV drives incorporate some additional circuitry that measures the motor power factor and adjusts the Voltage on-the-fly to hold the power factor within spec. Although SV has been around a good few years, I don't think the most popular of the sealed drives (Nema 4/4X, IP55-IP66) offer SV capability. The sealing is obviously more important than SV with metal dust about. At higher speeds, I cannot discern any real advantage with SV drives.
If you are limited at the bottom end of the speed range by the loss of smoothness at, or just below, 10 Hz, and at the top of the speed range by the motor designers maximum design speed of 3600 RPM. a 2-pole motor will give 10-60 Hz for 600-3600 RPM, a 6:1 turndown. A 4-pole motor will give 10-120 Hz for 300-3600 RPM, a 12:1 turndown.
It looks like the 4-pole has the advantage.
Because of the way that VFDs work, the speed vs power delivery profile of a 2-pole motor is different to that of a 4-pole.
Below the motor rated Frequency and Voltage, the VFD varies the Voltage supplied to the motor linearly with the frequency. This means that the motor operates in "Constant Torque" mode up to the rated speed. The Torque is directly related to the current, with the rated torque being developed when the rated current is drawn. Once the rated frequency and Voltage are reached, the drive can keep increasing the frequency, but the Voltage must be kept at the rated value. Above the rated frequency, the motor runs in "constant power" mode.
Power is Current times Voltage. The maximum current is whatever the rating plate says. For a 220V 3-phase 2 HP motor, between 6 & 7 Amps seems fairly typical.
If we take a 2 HP, 220V 2-pole (3600 RPM) motor and a 2 HP, 220V 4-pole (1800 RPM) motor and compare power outputs at various speeds:
At 300 RPM, the 4-pole motor is operating at 10 Hz and 37 V (10/60ths of 220V) and will generate 1/3 HP
At 600 RPM, the 4-pole motor is operating at 20 Hz and 73 V, to give 2/3 HP
At 600 RPM, the 2-pole motor is operating at 10 Hz and 37 V, to give 1/3 HP
At 1200 RPM, the 4-pole motor is operating at 40 Hz and 147 V, to give 1 1/3 HP
At 1200 RPM, the 2-pole motor is operating at 20 Hz and 74 V, to give 2/3 HP
At 1800 RPM, the 4-pole motor is operating at 60 Hz and 220 V, to give 2 HP
At 1800 RPM, the 2-pole motor is operating at 30 Hz and 110 V, to give 1 HP
At 2400 RPM, the 4-pole motor is operating at 80 Hz and 220 V, to give 2 HP
At 2400 RPM, the 2-pole motor is operating at 40 Hz and 147 V, to give 1 1/3 HP
At 3000 RPM, the 4-pole motor is operating at 100 Hz and 220 V, to give 2 HP
At 3000 RPM, the 2-pole motor is operating at 50 Hz and 183 V, to give 1 2/3 HP
At 3600 RPM, the 4-pole motor is operating at 120 Hz and 220 V, to give 2 HP
At 3600 RPM, the 2-pole motor is operating at 60 Hz and 220 V, to give 2 HP
At all speeds below 3600 motor RPM, the 4-pole motor seems to have the advantage.
Because power is Torque times RPM, generating the same power at half the speed requires double the torque. Usually, this means that the 4-pole motor of a given power is physically bigger than the 2-pole motor of the same power in order to supply the increased torque.
In the special case where a machine is designed around a specific motor frame size, going to a 4-pole motor might not be realistic, but in most cases, the 4-pole motor is the best fit to a VFD-equipped machine.
If your motor has ratings for both 50 Hz and 60 Hz, it can often be worth doing the sums for both sets of figures, as one will often give more area under the curve than the other. It's not always the 60 Hz values that are "better", nor is it always the 50 Hz values.
