- Oct 20, 2008
I just scored this motor for free, slightly used in a mechanical contractor's rubbish heap. Why it was thrown away I do not know, but while less than absolutely perfect for the application, (open frame construction, odd drive shaft) it has most of the things I was looking for in a grinder motor. 3hp, 3ph, 220/440v, 1725 rpm etc. Here is a link to the exact motor on Baldor's website; anyone care to take a quick look and give me some thoughts on whether this motor would be compatible with a TECO FM50 3hp VFD? I have seen some dust proofing measures invented for the open frame motors on some shop built grinders, but this motor is rated for max 40 degrees Celcius operating temp. Will adding dust filters cause it to overheat? Will this motor handle inverter duty use?
http://www.baldor.com/products/deta...otors_Pump&winding=35WGT676&rating=40CMB-CONT
Thanks for looking, guys.
