Grinder Shock..Och!
Greetings,
My grinder discharges static shocks when I grind metal. The shocks sometimes are 1/4 inch and are really starting to become unsafe and painful.
I thought it was only my grinder, but I am starting to get static shocks from my Balder polisher also. These shocks are very small compared to my grinder.
Any ideas what could cause these static shocks and more important, how can I get rid of them?
Note: My shop is 3 years old, but I did not have these shock last year ( I just started grinding again).
Thanks.
Dennis
First you want to make sure that the grinder is being used at a properly grounded outlet and that there is not a wiring problem. That being done what you are likely dealing with is just a static shock. They are pretty normal in a cold dry atmosphere with a high speed grinder. I use a beaded chain (like the pull chain for a ceiling fan) attached to the frame of the grinder with a gator clip and to my wrist with a rubber band. No more problems. Using a rubber band, there is little chance for injury if something should get caught in the belt, but you still want to be careful and keep it out of the way of the rotating belt and wheels. Just leave it attached to the grinder and slip it on when ever you need to grind something.
This question crops up about November, every year. Colder dryer air allows static to build up and cause sparks.
Some info on how static builds up:
With rotating dissimilar insulating objects that have a small contact area (car tires,grinding wheels,VandeGraaff generators), electrons are removed from one surface and build up on the other. Normally, they bleed back the overflow and all is even. When the conditions don't allow the bleed-off (dry, cold, fast moving surfaces) ,the build up can get into the 1,000 to 10,000 volt range. At this point, nature takes over and the imbalance cancels itself by jumping to a larger reservoir -the earth- which you are connected to. This is what a spark, or lightning, is.
To prevent it you have to allow the different potentials to constantly equalize.
Raising the humidity (pan of water on the stove was one common way to keep down static in households.), changing the dissimilarity of the objects (leather soled shoes, different rugs/floor covering, different clothing), or providing a path for the electrons to flow through ( ground straps, static strips).A simple ground strap is the easiest way to deal with it in the shop. There are some things that need to be dealt with though. First, it is imperative that all equipment be properly grounded to an earth ground. Water pipes don't do it well anymore. Second, an anti-static mat will help transfer the charge from you to the floor more efficiently. Third, if using a ground strap, it must allow the static BUT NOT THE AC current to flow. This is done by putting a 1 megohm resister in the circuit. Attach a 1 meg resister in the center of four foot piece of ball chain (hardware store).Wrap it in electrical tape to strengthen the joint. Attach a good size alligator clip to one end, and a 1X3" piece of copper to the other end. Stick the copper strip wherever it gets a good body ground ( In the boot/shoe side, in the waistband,etc.). Clip the chain to the machine, out of the way of all rotating parts.
This set up will allow the chain to unclip if you walk away, or the chain to break if caught in rotating equipment. Most importantly, it prevents the flow of AC if the motor should develop a ground fault. My strap has a clip on both ends, and I put a "U" shaped piece of copper in my waistband,clipping the chain to that. This allows the chain to just slip off if I walk away.This whole setup can be made for about $5, and will completely eliminate static shocks. Changing the shoes, using an anti-static mat, adding humidity and warmth to the air will all help,too.
OK, science lesson is over for today.
Stacy
Thanks Stacy, that's a good solution. Mine has so far been to just harden myself to the little shocks and move on. Besides, they're such a nice color! Sometimes I wish they'd last longer so I could get a better look at them. No, I'm just kidding. I'll try your ground method, as I'm glad for the resistor idea - that's what's kept me from hooking a chain to my machine in the past, the idea of having a hard circuit from my grinder through me to the floor...
Quit whining and take it like a man.
Its one of the many secrets of knife making that no one tells you about until you are hooked.:eek:
I have my grinders hooked to the electrified dog fence, so when I grind the dogs hair stands up on end.
You can take the advice of others, with a less adventuress spirit, but I think you will find, my way keeps you awake better and the dogs are a bit perkier also.
:rolleyes::D:D:D:D Fred
