- Apr 11, 2014
I built a 2x72 last year with a 2 HP, 1800 rpm, with KBAC drive. Now when I start it up it bogs or starts slow unless I pull the tension/tracking arm down a fraction of an inch or just enough to relieve a bit of pressure off of it then it goes up to full speed or whatever speed I set it at. Then it runs fine until I switch belts or shut it down and restart it. I only have a 40 lb gas shock on it. Maybe that's too much?
It hasn't always done this. It doesn't do it every time but probably about 80% of the time. It doesn't matter if I start it slow or at higher speeds. If I let it go too long before pulling on arm the drive will blink a red light and fault out. Anyone ever had any issues with this? Is it too much side pressure on the shaft? I really don't want to damage the motor or the drive.
Jay
Jay
