How do you figure SFPM. I have a 1hp motor at 1750 rpm at 60 cycles running a 2x72 grinder. Is that 10,500 SFPM? What is the advantage to more horsepower and/or 3500 rpm?
Belt surface feet per minute is the speed the belt is moving in feet per minute. It is a function of the Belt drive wheel rpm x belt drive wheel circumference in inches then divide the product by 12 to get feet per minute. Example 1750 RPM x 4" dia drive wheel (4" x 3.1416) 12.57" = 1833 SFPM.How do you figure SFPM. I have a 1hp motor at 1750 rpm at 60 cycles running a 2x72 grinder. Is that 10,500 SFPM? What is the advantage to more horsepower and/or 3500 rpm?
So that sounds crazy slow. Thanks for the help. Now I know why everything takes so long to do.Belt surface feet per minute is the speed the belt is moving in feet per minute. It is a function of the Belt drive wheel rpm x belt drive wheel circumference in inches then divide the product by 12 to get feet per minute. Example 1750 RPM x 4" dia drive wheel (4" x 3.1416) 12.57" = 1833 SFPM.
That is why I run a 3450 rpm motor with a 3 step pulley. At top speed I get 7200 sfpm for heavy removals. Then mid is 3600 sfpm, and low is 1800 sfpm. If you are trying to make a knife at 1800 sfpm it will be very slow and painful. Modern ceramic grit belts like 3M cubitron do not perform well at those low speeds. They like 6000 sfpm and up with heavy pressure to fracture the grit and keep it sharp and cutting. I get very long life in excess of 50 blanks per belt at 7200 sfpm with heavy pressure. When I got ready to build my first sander I saw this video.So that sounds crazy slow. Thanks for the help. Now I know why everything takes so long to do.
How does HP figure into this?That is why I run a 3450 rpm motor with a 3 step pulley. At top speed I get 7200 sfpm for heavy removals. Then mid is 3600 sfpm, and low is 1800 sfpm. If you are trying to make a knife at 1800 sfpm it will be very slow and painful. Modern ceramic grit belts like 3M cubitron do not perform well at those low speeds. They like 6000 sfpm and up with heavy pressure to fracture the grit and keep it sharp and cutting. I get very long life in excess of 50 blanks per belt at 7200 sfpm with heavy pressure. When I got ready to build my first sander I saw this video.. I decided that I wanted my machine to have that speed capability. Very glad I did. I feel that many are using underpowered and too slow of machines. Just my opinion. I love to make knives but I do not love standing forever in front of the sander to make one blade.
I don't have the book answer for that but seat of pantsometer seems to indicate 3 HP to operate happily at those speeds and heavy belt loads. My current sander has a 5 HP which is on there because I already it sitting a shelf. I am working on a new sander that will use a 3 HP with VFD. Will see how it handles the loads. I really like the tons of power the 5 HP puts out at high speeds. Hoping the 3HP will perform well.How does HP figure into this?
Thanks everyone for the help. I was grinding today and although it may not be perfect, my rig does carve metal. But now i know where I am headed. All the best.I don't have the book answer for that but seat of pantsometer seems to indicate 3 HP to operate happily at those speeds and heavy belt loads. My current sander has a 5 HP which is on there because I already it sitting a shelf. I am working on a new sander that will use a 3 HP with VFD. Will see how it handles the loads. I really like the tons of power the 5 HP puts out at high speeds. Hoping the 3HP will perform well.
