Thank you. I will fill out my profile soon. I think what I'm doing wrong may also be, when I'm profiling the blade and set my bevels, I don't work on the tip curvature too much. I flat grind to the desired width but I seem to want to leave more steel on the tip. I'm scared of heat treating a thinned out tip, so I leave it a bit thicker. Then after tempering I go to the grinder and attempt to set my final bevel at about 12*. I'm having difficulty grinding the final edge ( sharpening edge). When I do grind the tip, I use a bit more pressure. I end up screwing up the tip and my edge doesn't lay flat. I take a bit too much off the steel closer to the riccoso.
I will start from scratch again.
Question: on the current blade, should I put the edge on the grinder to level out the blade and then regrind the edge bevel or should I try to even it out by continuing to shape the edge and putting more pressure on the uneven part. Thanks
