- Oct 1, 2007
I have a home made 'KMG' type grinder. I work at a welding shop/machine shop and all of my parts were made there. The only thing I was not able to do was balance parts. (shafts, contact wheel etc.) Everything is square and true. My problem is a tracking issue. The belt tracks str8, or a least stays on track when set but it continually moves back and forth about 20 thou. with a 'wobble' type issue happening. It acts like the belt splice is out of alignment but I believe this not to be the case. (I have checked with several different types and makes of belts.) I have also tried different contact wheels and a slack belt attachment with the same results. :grumpy:
My idler wheel and contact wheel is bang on, checked with a dial indicator, and there is only a few thou difference in the drive wheel/pulley. The idler and contact wheels are square faced and the drive wheel has a slight crown for belt aligning. The drive wheel is secured to the shaft with two set screws in a keyway.
Does anybody out there have suggestions to get rid of the 'wobble'? I am going to try a square faced drive wheel with slight flanges on the outside to stop the belt from tracking off but I am not convinced this will work. Any suggestions would be very welcomed. Thanks guys. Kevin
