So I have made my first knife:
I messed up a couple things. Not sure why I put the later choil(?) directly under the edge. I wanted to make the blade mainly for chopping, but also useful for other tasks (not filleting fish or anything of the sort.) I ground the entire bevel at one angle, what I was guessing was around 20 degrees, but don't really know. On first test, the edge folded over. It was mainly at the bottom inch - inch and a half. I figured this was decarburization, so I kept going at the same angle until I removed the entire folded over portion of the blade, and evened the rest of the blade out a bit. I started thinking while grinding, that maybe the edge was just too thin. So I went to a steeper angle on the edge. This worked out alright. A couple more tests and it seemed to work well, no more folding (at least until we started throwing it and it hit other metal, then a little more folding happened - not nearly as bad though. Why did we start throwing it? Well, it is actually a really well balanced knife and I didn't care too much as this one was a learner.)
I have read a few threads that have stated thicker for chopping, thinner for slicing. My questions are, do you grind to the edge or do you put a second bevel on the edge for certain types of knives? What angles do you generally use for each type of knife (the stock I have at the moment is 1/8" thick?) My bevel is not as pronounced as others, should I have gone at less of an angle to make the bevel wider (when I was filing I felt this was almost too little of an angle, but the edge came to shape pretty quickly?)
Thanks a lot for reading this, and hopefully it is not too repetitive. I just couldn't find the right threads to answer my questions.
