- Jan 1, 2011
Hi everyone, I started some knives in CPM D2 and I'm having an issue. I'm very new to making knives and I've used my flat platen to grind the mill finish off of my knives after I have shaped them. I use a welding magnet to hold the blade while I push it into the belt. I alternate the blade direction so that it isn't always grinding the same direction and I use what I believe is even pressure on the whole blade. My problem is that I seem to be getting "pockmarking" that never gets ground away. I believe the pockmarking is just mill finish. My blades are getting thinner than I want them to be and the pockmarking is still there. I've been using Dykem to see where I'm grinding and the pockmarks are still there. Am I doing something wrong or does it take that much grinding to get all that mill finish off? I'm using a 36 grit at about 80% speed on my grinder.
