- Jul 23, 2015
Sorry, but can somebody me please articulate the "bump" being discussed? I'm finding this thread to be super useful but I don't know what you guys mean by that.
Ditto
HiSorry, but can somebody me please articulate the "bump" being discussed? I'm finding this thread to be super useful but I don't know what you guys mean by that.
Yup, that helps and I've seen it. Thanks.HiIdaho Savage When using a 2 in wide belt, you may notice that when you are really trying to get your plunge line right, that you thin out the section 2” away from the plunge…this is due to minor inaccuracies (hopefully minor
) on the edge of the belt that you aren’t paying attention to and due to the splice “bumping up” the thickness as it passes. So…if you get a “bump” that is 2” away from your plunge line, you get a 2” bump. Make sense ?
It’s tough to get it flat. I use this technique on large knives and specifically plunge less grinds like a chefs knife a good bit. I typically make 4-5 passes like this and then flatten the bevel back out in the normal fashion(using the whole 2” surface). I continue like this until the bevel is 75 percent or so and then just grind it normal. I find if I don’t do it like this I can get things pretty wonky and it takes forever to get thinks back flat. Hope this helps. As far as the 1/2” bump it’s more that your never grinding in one spot. The 2” mark is usually from holding the blade still against the plunge while trying to be delicate. The increased time in one spot combined with trying not to dig in too deep on the plunge is what causes the 2” mark.I'm just a complete novice and that's why I just read here more than post. I can see why this works in hogging off material faster but I would think instead of a 2" bump you could see a 1/2" bump. Enquiring minds want to know why this isn't true?
