Morning guys,
I've just ordered my first belt grinder, primarily to maintain and reprofile my chef knives and woodworking tools, but I'm a complete novice at any metal working.
One of the things I've learnt is that as a beginner it's always a good idea to start small, and so rather than wading into making my own knife all I'm looking to do at first are some minor alterations to my existing (expensive) knives, so I'd rather not destroy them through my ignorance. I'll use the older ones in the pictures to practice on...
Some images might help here:
Some of the tasks in prep work involve gripping a knife not by its handle alone, but by the blade as well. This is a typical grip:
The index finger curls around the shoulder of the handle and grips the blade itself between thumb and index finger.
The problem with this grip is that some of what I call the 'shoulder spine area' (I'm sure you guys have a real name for it) where my index finder now sits generally has quite a sharp profile.
You can see it particularly well in these photos on the left hand knife - the right corner of the spine is a sharp 90 degree edge and after a little while of using a knife like this really ends up rubbing your finger raw. The right hand knife is much comfier because of the transition.
So that's the issue.
The simplest solution would be to round over that corner slightly, or even better would be to create a radius in the spine that matches my finger (kind of like a slanted cylindrical profile). I know not to overheat the blade, but is there anything obvious why this is a terrible idea or things I need to remember while doing it?
Any advice would be gratefully received.
BASE
BASE
