Always room for improvement, and I still booger up grinds from time to time. Here's what I have learned works for me.
- Lock into a repeatable position.
- If you can't find a repeatable position (I and most makers like the platen about belly high, arms at a 90° angle) then raise or lower your grinder.
- Set the edge center by grinding at 45° using a worn 36-60 grit belt.
- Lock your elbows into your sides/ gut (this is one area where having a little bigger gas tank for the love machine is a GOOD thing
- Move as much of your whole body side to side to make the pass as you can. Just moving your arms can lead to uneven thickness from ricasso to tip.
- Concentrate on feeling the flat of the grind against the flat of the platen as you move that create the bevel up to the spine.
- I like to keep a very thin gap between the edge I created and the belt as I move the grind towards the spine. I then come back to bring the edge thickness to where I want it later on.
- The only aid I consistently use when grinding is a carbide faced file guide. It allows me to make my plunges even and removes one variable from the mix.
- If I was starting over knowing what I know now, I would have bought a bubble jig from the get go.
- You should be "in the zone" if you are doing it right. By this, I mean with the noise of the grinder drowning out everything else (or your hearing protection muffling out noise) you will be totally focused on what is happening with that grind against that belt. VISUALIZE what is happening. Your hands will tell your brain if you are flat against the belt, use that information to stay in the zone.
*** The following is not generally accepted advice I have seen, but it worked for me***
You shouldn't try to use really thick stock for early knives BUT (and this may be just my opinion) using thicker and taller stock (like 1/4" thick/ 2" high) can help you see and feel what is happening when you are grinding better. It also can give you some leeway to correct issues in one session. I'm not saying to make knives right out of the gate with thicker stock, but to
learn, I personally saw a benefit. Maybe get yourself a 1/4" thick x 2" high piece of steel and make yourself a chopper. If it winds up less then perfect, it will still be a great tool around the yard.
Hope this helps. I know it can be frustrating, but practice makes perfect (or as close as mortal man is able)
