I don't think it's the tang that's rough, it's the axis lock sliding on the liners that is causing the roughness, exacerbated by the axis lock being a mm or so wider than it needs to be so that it cocks sideways if you try to actuate it from one side. It's smooth if you pinch it w/ thumb and forefinger, but rough as a cob with thumb only.
Maybe this was a running design change for the worse? I swear that one of the grips that I looked at in the gun shop I took a close look at it and it looked like it had a torx recess in it to screw apart. Mine however does not. If it did come apart I would definitely either add a PB washer or just file the female side a little shorter to tighten it up.
Or do the ones that screw apart not actually have recesses for tools and you need to use e.g. shelf liner to grip them & unscrew? In which case I need to disassemble mine, warranty be damned.
I noticed the same roughness on the REI edition Grip and commented on it in that thread.
Are you in any car forums? Your name looks so families every time I see it...
Anyway are you sure you weren't looking at the thumb studs? The thumb stud has torx heads cut in them for removal but I've never seed an axis lock (and I know this isn't alot by any means but I have 4 current axis knives ranging from brand new to an OLD 710) so I think, unless its a brand new design change, that I would of seen that before.
