you can make a custom griptillian on benchmades site. its costs more, but you can order it from them.
Wow. I didn't realize that. Thanks for the info.
Was the knife I described a production knife?
Not flat ground, rather hollow ground with the thumbhole.
There looks to be no option for a thumb hole on the custom build. I'm thinking the knife I described was a production knife, but I've yet to find out the model number & if they still make it.
WS it round hole or the oval hole? You got me thinking now, Benchmade used to oval hole for several years then dropped it in lieu of the round hole. Or it was simply a franken-grip, made from 2 different knives.
The last three posts excluding ccf's #14 post have all said Benchmade 550 Griptilian HG. If that hasn't sunk-in, or if it is not what he is looking for then the old saying; "beating a dead horse" is appropriate here. My two posts alone gave enough details about the Benchmade 550 Griptilian HG to lead even the most amateur of pirates to the treasure.![]()
If this was a production model, I believe it would have either been 550BK (or SBK if serrated) or 555BK (or SBK) for when it had the oval hole, and 550BKHG (or SBK) or 555BKHG (or SBK) if the current round hole model. Otherwise, it was a hybrid, custom build, or a limited run (which as far as I know does not exist). The Grip has always used a hollow ground sheepsfoot on the Grips with the ovals (earlier)/circles (later and current). It's a nice grind.
The Griptilian with the flat grind is the Ritter Grip and Mini Ritter Grip, which uses a high flat grind, thumb studs, and S30V blade steel (and it's one helluva blade).
