Grizzly 2x72 Belt Grinder
Has anyone worked with the Grizzly 2x72 belt grinder? I'm seriously considering picking one up. The $400-500 price is very attractive. Or, does anyone have any other recommendation in that price range? That's about all I can get appropriated through congress (wife) at this point. :)
the grizz will work, but i recommend in that price range getting a Coote. That was my first grinder until I got a KMG, and it's still wicked useful around the shop
The grizzly is a excellent grinder and buffer combo for the money. I've had one for 7 yrs and no problems with it . If you plan to hollow grind with it get the 10" wheel or your knuckles will hit the motor as you grind to the left,guess thats why I bought a KMG as I have the 8" on mine.Once you progress the griz is always great for shaping and hogging steel. I don't regret mine at all.
The Grizzly is still one of the most used tools in my shop. When mine died, I immediately ordered another. I have an expensive Hardcore grinder, too. If I had to get rid of one, I would keep the Grizzly-it's not a better grinder, but it is more versatile.
Thanks for all the comments! That'll be my next purchase. Time to move into the stock removal phase. :)
It work's great and is easy on the wallet. I have two of them and both function great. Buffer arm sucks. Can't find muslin sewn wheels that fit it. Loose wheels on it are very dangerous!! Ouch!! Put a ceramic platen on it and you are good to go. 10" wheel is only good if you do a lot of hollow grinding.
I went this route, except first it was a Sears 2 X 42, then the Coote, then the KMG. Coote is a much better machine than Grizzly because it is pulley driven and that offers you a three speed set up or even a variable speed motor. Coote is pretty simple, fasten it down and hook up your motor system. The Grizzly is a one speed system and direct drive. The arms on the Grizzly use round stock for the arm and the Coote appears to be cast. Coote is a heavier and better built machine. I think the Grizz can still be had for around 400-450 range while the Coote is 495 for the best one, and then you will need to get a motor....
It's a very versatile grinder, these were made using my Grizzly around 4 years ago (I started knifemaking in '04):
The 10 inch wheel is good for hollow grinding and the direct drive gives you sufficient speed for fast stock removal. The flat platen is great for flat grinding, although a piece of pyroceram JB Welded to the platen really improves your grinds. It's a great way to get started. I have a KMG now, but for the money and lessons learned, the Grizzly was a great investment. :thumbup:
I'd think the Coote might be more versatile. If I had it to do again, I'd probably go that route.
That being said, my first grinder was a Grizzly, and I still use it for every knife I make during handle shaping. It has some tracking issues that can be improved by wrapping a few layers of electric tape on the crown of the tracking wheel. Also, take a cheap foam vac style filter and tape it over the vents in the grinder to prevent metal dust from entering the motor housing.
The Grizzly runs pretty fast and being direct drive cannot be slowed down in any way without extensive modification. Also, the motor isn't the most powerful and you will tend to bog if doing really heavy grinding. But all of those things can be worked around. You might want to check into getting a pyroceramic platen liner to replace the graphite liner as it wears. It will give you a more true flat and wear much better. Darren Ellis carries those in various sizes.
I've said before that if you can learn to grind well on a Grizzly, you'll have a much easier time when stepping up to a better grinder. It takes a delicate touch and a good amount of control. Don't expect perfection from the very first blade as there is a learning curve to grinding on any grinder. Go slow and gently, and you'll quickly learn how to fix mistakes in your grinding.
--nathan
The Coote I had tracked excellant and I bought a 2hp WEG for it. I never bogged! LOL I am not a sales person for Coote, but it is alot better machine, built better and has replaceable bearings. You can get attachments for the Coote. I am not taking a shot at anyone who has owned or used a Grizz. I am just offering advice on how to spend your hard earned dollars on knife equipment...
Just when I thought the decision was made, the Coote guys make good points. I definitely need the 10" wheel, gotta learn the hollow grind. Thanks everyone for your insights.
I love my Coote. It was my first grinder, so it really sped things up compared to using files! My girlfriend has taken an interest in knifemaking, so we may add a second grinder to the shop when finances allow. I have Tracy's plans for the NWG, and that might end up being our #2. I bought the Coote more for the instant gratification aspect, but now that I have a good grinder, I can see spending the time to build the NWG. I guess it depends on how much of a hurry you are in. The Coote really is a solid machine, and I couldn't recommend it enough.
You can hollow grind on the Grizzly 8" wheel-it's just more difficult.
Use a magnet to hold your blade and you can hollow grind on the 8" wheel.:cool:
then you can use a grizzly 10" wheel on your NWG:D
So, if I were to get the Coote, or go big time with NWG, where would I get a motor like that?
grizzly.com carries them, Harbor Freight, Baldor Motors, etc etc....
http://grizzly.com/products/searchresults.aspx?q=TEFC Motor
Single phase motor unless you have some Godly 3 phase power !!
you want atleast a 1HP 1725 TEFC (Totally enclosed fan cooled) motor in either 110/220 Volt. Don't buy a 3450 or 3600 RPM Motor as i don't think they are recommended by Norm Coote. Or just may be too fast completely for the coote model.
I would also suggest you filing out your profile as some users tend to NOT answer questions to people they have no clue about (age, where you live state wise, etc etc)
The NWG (as you probably alread know) is a grinder you'd have to build yourself :D
I've been considering getting a Grizzley with a 10" wheel, but the manual says
"If you use the optional Model G9242 10 drive wheel, you need to use a sanding belt that is longer than the included 72" belt" .
Does anyone have experience with he 10" wheel? Would I need to find special belts, or is there a minor modification you can do to the machine to allow 72" belts?
