- Dec 6, 2011
I received my 6" Grizzly height Guage/scribe. The little brass colored flat spring with a bent hook on each end was loose in the box. I figured out it goes behind the micro height adjuster piece and the mount the dial indicator is on, on the lock screw side.
I have it in place, but the micro adjuster only works to raise the scribe, and will not move it downward when turned the other way. I am assuming I have it installed wrong? Is the flat spring supposed to be bound by the tiny set screw on the lower portion, right above the thumb screw?
It's certainly useable as is, as long as I don't overshoot a bit and need to make a small downward adjustment. Any advice would be appreciated. I bought it through Amazon Prime and am tempted to return it and get another.
