peel off and throw out the graphite tape stuck to the platen it's crap and develops furrows, when I get the chance I'm going to order ceramic from Ellis, right now I use bare steel, it works. the work rest is a great invitation to get stuff caught and thrown, it's also the most rube goldberg kluge I have ever dealt with. Grizzly belts are crap, it came with a 2x80, I ordered some 2x72s with it, they don't last at all, they break quickly, don't cut, and the abrasive powders all over everything, get real belts. Don't have anything directly under your belt, had a plywood mounting I assembled it on that stuck out under the belt, it now has a half inch deep charred divot where the sparks built up and burned (my stepfather insisted on not hanging it over the edge of the bench, it's his land my machine shop is built on, can't argue so now there's a metal plate ) you might have problems trying to limit the speed on the motor by cutting voltage, as it will try to make up for it with amperage and fry your windings. there was some discussion of metal dust getting in the gill openings on the bottom, the best suggestion seemed to be putting a piece of pantihose net over the opening
-Page
