I have 120/240 for my lowest stones. But I used a extra coarse diamond to take it down to 20 degrees. Kinda wish I kept the factory angle now. As soft as it is I can see why they have it that steep. Oh well. Live and learn I guess. Nothing else will make a great kitchen knife now. Lol
Might seem counterintuitive with 'soft' stainless knives, but I've come to firmly believe they don't do much better with a wider-than-usual edge angle, in trying to compensate for the
perceived softness of the steel. When push has come to shove, I've always taken them at least a bit thinner to improve the way they cut from the outset. 'Soft' steel (ductile steel that's more likely to deform instead of chip or fracture) will still deform easily, either way. If it's edge is thin, it rolls more easily; if it's still fairly thick, it'll 'deform' by denting or flattening of the apex.
The advantage to thinner geometry is, it'll at least cut much more easily for a while. By contrast, an edge that's deliberately made wider in angle will never cut as well from the start, and will only get worse in cutting performance as the edge wears.
Even with my cheapest-of-the-cheap kitchen knives in soft stainless, I've always eventually thinned them out, sometimes extensively, to improve how they work. I've always found it surprising that doing this has made them better overall, even if it means they'll want for more frequent touching up (and it's easier to do this with a thinly ground edge).
Looking at Grohmann's own description of their blade materials (see link & quote below), they say their 4110 stainless is hardened in the HRC 56-58 range. This is essentially the same ballpark as other makers use with similar steels, like Case's 420HC (55-57 HRC) or Victorinox's stainless steel (also around 56HRC). With these knives as my basis for comparison, I've found all of them to work well at 30° inclusive or sometimes a bit lower, down to 25° inclusive or so. With a hunting knife, maybe microbevelling could be useful also, for some harder work. But essentially, such steels seem to do pretty well in most tasks at 30° inclusive (15° per side) for starters.
( Quote below is linked from their site here -->:
http://www.grohmannknives.com/index.php/about/materials-we-use )
"...Grohmann's most popular stainless steel in the outdoor fixed blade knives are fashioned from German high carbon stainless, such as 4110, which is somewhat comparable to the USA 440 series. We maintain a 56-58 degree rockwell hardness on all outdoor knives."
