Gun Safes
I'm not sure that weight is all that important. Most safes can be bolted to the floor and/or walls.
I have a very old Cannon safe that is made of 1/4" plate on all sides including the door. It weighs 650 pounds. I know that because it cost me 50 cents per pound to move it.
It is not fire resistant and cost me $600 in 1990. Based on inflation, todays safes are much cheaper.
I recently looked at a Cannon safe that Costco sells and was dismayed to find that they are made in China.:thumbdn: I don't know if all their safes are made in China.
My boss has two Liberty safes. They are nice.
I can say that Graffunder makes one of the very best! They cost a few bucks but you'll never second guess your decision.
Thanks for the additional info folks, but I'm pretty settled on the Sturdy Safe. It's been a very worthwhile study as I've researched these Gun "Safes"... I won't refer to them any further as a Safe, but will instead, call them what most of them actually are; Residential Security Containers (RSC's) and are rated by Underwriters Laboratories (UL) as RSC's. In order to get the the UL-RSC burglary rating, essentially, the container must withstand break in attempts with common hand tools for at least 5 minutes. Don't confuse a UL-RSC burglary rating with a UL fire rating! The UL fire rating is a whole other kind of animal! There is a BIG difference between an actual "safe" and what most companies market as "Gun Safes" (that are actually RSC's).
I'd like to throw out a few things I've learned for others who might benefit.
Most "low end" RSC's sold by MANY companies ARE made in China, from Chinese steel which is 35% softer than American steel. These China-made RSC's are "formed" in China and assembled and "finished" in the US and some companies will sell them as "American made". Cannon for example, makes a few of their high-end, most expensive models in America for example (from the ground up), but most of their mid to low end RSC's are "created" in China and are the exact same Chinese product that is sold by other, notable RSC companies (Winchester, Bighorn, Rhino, Sentry, Browning etc.). Some have their RSC's "created" in Mexico as well. They all buy the same exact Chinese/Mexico steel "container" built to different specs so far as number of locking bolts, locks used, etc. but are essentially the same products from China/Mexico. If you are looking for a truly American made RSC (American steel and locks etc.), you had better do your homework no matter which company you are considering (with just a few exceptions as far as I have learned).
RSC Construction; How thick is the steel used on the entire shell of the RSC? The door? Many, MANY RSC's advertise 12ga., 11ga. or 10ga. steel as the outer shell steel, with any number of thicknesses used on the door (3/16, 5/16, 1/4 etc.). The pointed end of a fire ax will puncture 12ga. with relative ease, and 11, or 10 is stronger, but minimally so. Consider that a "true safe" measures the steel thickness in inches, not in gage... in INCHES of steel. Some of these RSC's are created from individual plates of 12ga. steel that are then welded together to form the box... sometimes they are "stitch" welded together rather than continuously welded... stitch is inferior. Stitch AND continuous welds are both inferior to a single piece of (12ga.) steel that is "folded" and bent to form a "box" which contain as few welds as possible (break-bent). If you were actually buying a real safe, made from 2-inch, 4-inch or thicker steel, it would obviously be made from separate plates and welded together (but we're not talking "real safes" here). In a 12ga. RSC, it's welded, and then the welds are ground smooth for appearance, creating a much less secure weld.
Doors, hinges, locking bolts and the locking mechanisms; The thicker the steel on the outer surface the better. Be careful here because many companies will tell you the total thickness of the door itself, without describing the actual thickness of the steel used.
From what I have read about hinges, external hinges are the way to go. Internal hinges don't allow a full swing open for most doors that have them. If you swing an internally hinged door open TOO HARD, it can cause issues with the hinge and the doors ability to seal tight. External hinges have a couple of benefits; They allow the door to open fully, they are "serviceable doors" (can be removed when open for servicing or just to reduce weight when moving the beast around), and they may draw a criminals attention as a possible point of attack (which is a waste of his time if the door has bolts on the hinge side of the door... and most RSC's DO have locking bolts on the hinge side as well as the opposite side). A door with bolts on the hinge side will keep the door locked onto the RSC even if you were to saw off the external hinges.
Locking mechanisms in these RSC's can be very complicated and quite intricate... many of them have locking bolts in any number and possible configuration... 6 locking bolts, or 15 locking bolts or even 28 locking bolts that are advertised as being on both sides AND the top and bottom of the door (or only on the sides). More bolts sounds good in theory, but it isn't necessarily so. Some of the very best ACTUAL SAFES in the world have no more than 6 locking bolts which are on the sides of the door (none on top and bottom). The design of the bolts and how well they are supported by the door itself is more important than the number of bolts that exist. Some locking mechanisms (the gears/clutches inside the door that move all of these locking bolts when you spin that big five spoke wheel) can be complicated and quite intricate. Some can also be quite "delicate" to accidental damage. Many are designed to foil a burglar who tries to forcefully turn the wheel to open the door by sheering off internal pins or by disengaging a clutch. If your little 3 year old girl tries to play pirate and spins the "captains" wheel with much force, she may sheer a pin or clutch and now you will need a locksmith to get it open. I've read many forum comments where this sort of problem happened to quite a few people (a rifle sling got closed in the bottom of the door and the door was forced closed on it. When the time came to open the safe, excessive force was necessary to turn the wheel and the pins inside the mechanism sheered off, necessitating a locksmith). Some mechanisms are better than others in this regard so do your homework.
Locks (combination/electronic); There are basically a couple of common options... the ol' standard round, mechanical combination type or the electronic, keypad type. After what I've read, I personally wouldn't buy a safe with ANYTHING other than an ol' fashioned, round, mechanical combo dial you spin. I don't expect to need quick access to what's inside the safe (house gun's in my pocket;)). Big, big problems noted with electronic keypads. Keep in mind that all locks are not the same quality either (combo or keypad) and each may or may not carry a UL rating and may or may NOT be an American made lock. Many RSC companies will only warranty the Lock for one year, even though they may have a life-time on the rest of the safe... check before you buy.
Fire"proofing"; First, this is a misnomer... no RSC is fire "proof"... actually, most REAL safes are not fire "proof". Most of the RSC's I investigated DID have some sort of fire resistance built in, but fire rating these things is like trying to heard cats:mad:... there are few if any standards at all. IIRC, the UL does NOT fire-rate RSC's... they DO rate real safes, but not RSC's because RSC's just aren't up to their minimal fire test criteria (other independent fire-rating companies DO test these RSC's but beware! They are being paid by the company to test the product in the way that the company asks them to test). IMO, an RSC with some/any sort of fire resistant material IS better than the same RSC without, but it's a crap-shoot.
The problem with trying to protect the contents of an RSC during a fire gets complicated because these are NOT safes, they are RSC's. Most makers of an RSC use a thick(er) steel on the outside, some fire resistant material (sheet rock) attached to it, and then perhaps even another interior sheet of steel inside that (thick exterior steel with sheet rock "sandwiched" between it and a thinner interior steel). The thicker the exterior steel, the better it will heat up and transfer the heat to the inside of the safe.... this is an inherent problem when it comes to "fireproofing" an RSC. They try to make them thick to protect against a burglar, but then they try to protect them from fire and the two goals are contrary to one another. For example and in contrast, a REAL SAFE that really DOES have a good UL-fire rating is made of a thinner steel on the outer shell, with INCHES of fire resistant material sandwiched between it, and the VERY (inches) thick steel inner liner. It's like a thick steel SAFE, surrounded by fire-brick, then covered by a thin outer-shell of thin steel. Thinner steel on the outside will "collect" less heat to transfer to the inner compartment. RSC's are just the opposite, so NO RSC is really going to be nearly as effective as a "real fire safe". If you want a REALLY good, UL-fire rated gun SAFE, buy one from Brown and expect to spend from $10 to $15 THOUSAND or more for a "smallish" one. If you want more details about fire "proof" RSC's let me know... I spent a lot of time at the UL website.
Let's see... China vs. American, general construction and steel thickness, doors, locking bolts and mechanisms, locks, and fire"proofing"... what am I forgetting? Oh, warranties and why I am going with a Sturdy Safe.
Warranty; Many company warranty their RSC's for a lifetime, but don't cover shipping if you need to send it back... Shipping an 800 pound safe is expensive!. The warranty might not cover a locksmith if little Sally decides to turn the wheel HARD-a-starboard and shears a pin. Might not have a lifetime on the lock etc. Read the warranty VERY carefully. Even Cannon (who's warranty is touted) has some fine print in there.
The Sturdy Safe
  • American made (100%... steel, locks, you name it).
  • 7ga. steel outer liner (roll, break bent).
  • 5/16 plate door.
  • External hinges.
  • Sargent And Greenleaf Premium Grade Group II Combination Lock (UL and American made).
  • 2 relockers.
  • Heat expanding door seal with fireproof boiler gasket (actually a fire proof gasket... like the seal on a wood stove).
  • Fire "proofing" consists of 3 "of 2300° Ceramic Wool & 1000° High Temp Glass sandwiched between outer (7ga.) and inner (14ga.) steel (around the entire container, not just in the sides or just the top... check this if you are looking at others!).
  • A "simple" locking mechanism that isn't susceptible to over-pressure on the handle (playing pirate).
  • Supported locking bolts.
  • Lifetime warranty and against fire (see fine print!).
  • 850lbs. (weight CAN be a good indicator of steel used).
For the price (just over $2000 delivered), I can't find a better RSC.
I'm sure I've left out some important bits, so if you have questions, hit me up. Always glad to share.
I'd advise anyone who's looking for a "gun safe" to look at the Brown Safe Co. website first to see what a REAL, fire"proof" gun SAFE really is (for $13 thousand) and then work your way down from there to a more affordable, RSC.
To add; The criteria for a "gun safe" for me, was to have some fire protection, very good protection from the average "snatch and grab" type burglary and at a price point (delivered) of around $2500, more or less.
I'd love to have a Brown, but that would be more expensive and valuable than all the stuff I'll put in the safe... and then I'd need another larger Brown safe to secure the smaller Brown safe... and then another.... could get expensive eh?:D
Thanks for the great information timcsaw. Your comprehensive research ought to be a sticky here. If you don't mind my asking, what is the capacity and inner configuration of the RSC you will be getting (I should just go look at the Sturdy Safe sight and quit being lazy)? Mike
Thanks, I'm glad to be of help Mike.
I've opted for an interior with a top shelf, and side removable shelves similar to the one shown at THIS link (the bottom one with fireproofing).
Mine will have a 15 long-gun capacity.
Hands down Ft. Knox. USA made, family owned company. !00% lifetime warranty on everything but batteries in the electronic lock.....and customer service that is 2nd to none. Sucks steel prices are so high but Ft. Knox rocks, own 4!!!!!!!!!!!!
Agreed... one of the best RSC available IMO!
That is a fantastic summary. That single post is a must-read for anyone contemplating a "safe" for his home.
Just about all of the "better" RSCs use Sargent And Greenleaf Group II locks when a mechanical lock is called for. The dealer or any locksmith can replace that with a Sargent And Greenleaf Group III lock; it just drops in to the exac same mounts. The difference is that a Group II lock accepts a combination +/- 1 digit on each number. So, if the combination is 20 40 30 and you dial in 21 39 31, it will open. A skilled "safe cracker" can take advantage of this; it takes the number of combinations from 1,000,000 down to 111,111. A Group III lock requires you to hit the numbers +/- 1/4 digit, basically right on. And, a nice detail is that there is no way to tell from the outside which lock a container has.
The S&G Group III is the same lock used on bank vaults (they often add a time lock mechanism). Those S&G lock mechanisms are the result of decades of experience at S&G and are very good.
Just how effective any RSC will be at either fire or theft protection has a lot to do with where you physically put it. For fire protection, do not put the RSC in the middle of your house. If the house burns down, that will be the hottest part. Instead, put the RSC on an outside wall. For security, most thieves do not routinely carry safe-breaking tools and prefer not to do that hard, noisy, time-consuming work on-site. Instead, they take the safe intact and break it elsewhere. So, bolt it down and put it in a place where it is hard physically to get it out. The harder it is for you to get it in, the harder it will be for them to get it out.
Although a good safe is an absolute "must have" the most important thing of all which I didn't see anyone mention is a good Firearms and Sporting Goods insurance policy. Almost all homeowner's policies have very limited coverages for firearms and other specific valuables and you will need to get a Rider issued from your insurance company for the amount of dollar coverage you need for your collection. Any safe can be burglarized or possibly you could be forced to open it at gunpoint in a home invasion scenario. A good firearms insurance policy will be worth it's weight in gold at that point. When you have both a good safe and a good insurance policy then you have the best of both worlds.
Here is a firm which has been around for many, many years and their prices are very reasonable for the coverages they provide:
http://www.collectinsure.com/index.html
I would rather have a cheaper safe and a good insurance policy than a good safe and no insurance.
what fort knox models do you like ? Which size sturdy did you go with?
Although a good safe is an absolute "must have" the most important thing of all which I didn't see anyone mention is a good Firearms and Sporting Goods insurance policy. Almost all homeowner's policies have very limited coverages for firearms and other specific valuables...
An excellent point, Mr. Alex. Most off-the-shelf policies have only maybe $1000 coverage for firearms. That can be just one or two guns.
Fort Knox Legend, Titan and Executive are the models I would have considered, that are (IMO) nearly as good as the Sturdy. I didn't care for their internal hinges, their use of "fireboard" (sheet rock) as an insulator, and their locking bolt mechanism is more prone to shearing pins/clutches in the event the door is jammed (by a strap or spun hard by the little girl playing pirate). Their lower end RSC's (below those mentioned above) use only 10ga steel as the body material. Those 3 models listed above use thicker steel but pushed their price beyond the Sturdy Safe. Don't get me wrong, Ft. Knox makes a very good product, but I think you get more "bang for the buck" with a sturdy.
The Sturdy Safe I am interested in is a 15 gun model, 27w - 23d -60h. It isn't perhaps large enough for a gun collector, but it is plenty big for those arms I will store in it.
Good point alex about having insurance. During my research, I read that insurance companies STILL end up paying for the contents of RSC's about 86% of the time after a house fire. The guns may not have burned, but they are still often unserviceable.
Thanks for the kind words Mr. Gollnick , you also gives wise advice about where you install the RSC. An exterior wall or corner is much better than in the center of the house. My Sturdy will go into a finished basement in a corner, with a framed wall/closet built-in on the one exposed side. I will also bolt it down even though it weighs 800lbs. It will be in a position where it is difficult to get at.
Thanks for the reply. I was just wondering the size, because I thought for it being made of 7ga. outside and a 14ga. inside 800lbs sounded kinda light.
@TimCSaw:
As a licensed locksmith, the company I worked for was the only dealer in the DFW area to sell Fort Knox gun safes. While I am not familiar with Sturdy, I did have a chance to visit their factory and see how the safes were made in Orem, UT. I must say, I was very impressed. While it appears that Sturdy Safes do make a very reliable product, I can certainly vouch for Ft. Knox's quality, and customer service. Their safes hold up extremely well and truly are built one-by-one. Go with whatever you deem, however, I would say hands down Ft. Knox beat Liberty and Cannon.
@TimCSaw:
Thanks for the input David... It's always good to hear from someone in the biz! I was very impressed with the Ft. Knox RSC's and do think that they make a fine product... they were definitely on my short list of possible choices.
I expect my Sturdy Safe to be delivered today or tomorrow and will post some short comments about my impression of it when it arrives.
Thanks to Mr. Gollnick and all of you others who offered opinions and advice... I greatly appreciate your help.
