This is very good advice. Listen to it.--KVGood quality from Himalayan Imports, sub forum on here, the villager models are a good catch.
When you say your Kukri House models is not good is that the Kukri House Handicraft Industries (KHHI) or different manufacturer ? Do you have a link to the real Himalayan Imports website ?
Just to throw another name into the ring, I have a few Khukhuri, I was very impressed with the most recent one I ordered from Kailash Blades, I ordered their 'Pensioner' model from their Traditional range, and it's a very nice piece indeed. They're well worth a look.
Kailash is really underrepresented on the forums since it’s still a new company, but the quality is far and above the other three players. KHHI uses a process that makes the edges prone to rolling, quenches poorly, and the spines are too thick. Himalayan Imports makes them too heavy and way above recommended weight. And Tora takes three to 4 times as long as Kailash to make a blade but doesn’t even offer refunds or warranty. My Historical Service Issue from Kailash is all I was anticipated when I ordered others but never got until 2 days ago when it arrived and I put it through its paces. Can’t recommend them enough, they’re bound to be the next big thing.
I don't have any problems with all my "KNIFE MAKERS" links on the desktop apart from kailash. I get blocked from entering a couple of their links for some reason!
I get to see the gallery though for reference.
Their website is a little buggy, but their customer service responses are the fastest of all the other companies. Might suggest they upgrade
This.+++ Good advice. My HI KVLUK is one of the most useful blade purchases I've ever made--KVGood quality from Himalayan Imports, sub forum on here, the villager models are a good catch.
Just as an update, we have our on subforum now!
Not a heap on it as of yet, but if you've got some photos you can post then chucking them in this thread here would be a big help.
Take care,
Andrew
I have never seen normalization mentioned in respect to HI, and from watching KHHI´s "How its made" videos, it does not look like they do it either, though some effect might be had from both parties due to the constant heating cycle the kami´s used. 5160´s properties, namely grain size, shows major improvement from a properly executed normalization cycle, and it might allow a party that does so to make their knives thinner than the competition, while not sacrificing strength. I tend to like a thinner kukri myself....The kamis, in my opinion, are more or less abusing 5160, (repeated heating and forging which should lead to mad grain growth, water quenching, no normalization and no controlled tempering, AFAIK the only tempering is in the residual heat of the blade after quenching) and still getting good results. Not to mention they typically use recycled steel of unknown quality. There is some research to be done to help explain why the results are pretty bloody good and consistent.
How long is your waiting list for new orders?Hey there mate!
You've pretty much hit the nail on the head with a lot of this. Normalisation does a few things for us, which are all linked in with our other processes. We also all have experience working with KHHI and other houses, so can make some sound comparisons.
It allows us to relieve the stresses from forging, but most importantly the stresses from the steel's previous life as a spring under a truck for 30 years. While this reduces the chance of failure over the lifetime of a blade, for us it's crucial because our oil quench is a lot harder on the blade than a traditional water and teapot quench. It more or less eliminates the likelihood of cracking and lessens the amount of warp that results.|
It also reduces the grain size, which decreases hardenability and makes our oil quench gentler still. This is fine as we're only aiming for moderate hrc on our blades. It also increases sharpenability, which helps with field maintenance while also bringing the sharpening experience closer to traditional blades, which are seldom touched by stone or ceramic.
A smaller grain size as well as our tempering procedure both allow for a tougher blade at a higher hardness. No other house in Nepal tempers their blades in any meaningful way and it leaves them having to walk the line between an edge that rolls or cracks. That sweet spot occurs at a much lower hardness for them, with our processes giving us much, much better edge stability. We offer a few types of grinds to best take advantage of this and generally go much thinner for better performance while landing at a similar if not slightly more durable edge.
With all this said though, there are some benefits to the traditional quench. Our blade design and heat treat process is optimised for performance while the standard method is geared to be economical and have a low rejection rate.
While water quenching is typically harsher than oil, the nepali way of pouring it out of a teapot makes it much, much gentler. The lower thermal mass from it being poured on gradually rather than dunked means that it cools at a very slow rate. It also doesn't quench as deeply, stressing the inside of the blade less. This makes the blades much less prone to warping, cracking and lost work. The lower rockwell out of the quench allows them to passibly avoid temper completely and also makes for an easier and quicker grind/sharpen. This all saves money and speeds up production.
To compensate for the lower strength of the softer, untempered blade, the vast majority of khukuris in nepal are ground very thick, much thicker than would traditionally be the case. This allows for a much more stable edge, primary grind and also means they have to take less steel off the blade when coming down from thick stock. This once again saves on labour but also reduced the likelihood of hitting a void and needing to scrap the blade. A final benefit of a softer, thicker blade like this is that it's much less likely to break catastrophically in use, meaning less warranty claims and the ability to market the blades based on that benefit. HI got a large foothold in america through advertising their panawal angkhola as being the toughest knife in the world, if you break it you get sent two more and KHHI and their imitators do similar things nowadays. I've seen my fair share of snapped khukuris and in the majority, you're right that an enlarged grain structure is usually but not always present. I doubt you'd need a microscope though, it's usually chunky enough to show up in photos.
As a comparison of blade strength, a standard ground blade from KHHI is almost always tough enough to chop buffalo horn very hard without chipping or rolling. When I was working for KHHI I used the current Kailash heat treat on one of their grinds and it could chop and carve rebar without issue. Our standard grind is closer to what tora put out and shows similar cutting performance but with ours being capable of much harder use. Our performance grind is leaner still and would most likely not hold up on a tora and would certainly crumple on something from KHHI.
Important side note: Not all manufacturers in Nepal are currently using 5160.
Neem tenji of gurkhasblades plasma cuts all blades and KHHI plasma cuts any blade that isn't rat tail tang. While this brings in it's own issues in terms of heat control at the edge etc, it forces them to use sheet EN31, a 52100 equivalent. 52100 is a lot less forgiving steel due to the higher carbon content making it much less suitable for water quenching. Furthermore while it does have increased chromium for depth of hardening it doesn't make up for the reduced amount of manganese. This causes shallow, harsher quenching and is in general a worse match for the teapot method and I'd expect more blade failures as a result.
Anyway, a long post but hopefully it's informative and covers why normalisation is crucial for us and also how current nepalese blades hold up so well with such a basic traditional quench.
Usually from receiving payment it's about 5-7 weeks including shipping time but now is a particularly slammed time. We had a review from skallagrim recently that's had us operating slightly over capacity with orders (2 week delay) and also have the Festival season in Nepal coming up where the hwole country shuts down for about a fortnight. So right now about 9-11 weeks but once Dashain and Tihar have finished we'll be back to normal.How long is your waiting list for new orders?
Hey there mate!
I have always wondered about the cho surviving that process of optimization, as its existence from a pure engineering standpoint contributes nothing and serves as a massive stress riser... In addition, the initial teapot quench allows for the residual heat of the blade to temper slightly, and the traditional handle fitting heats up the tang to red hot, and it seems reasonable to think that the base of the knife would be tempered again by this process, so that this area would likely be a ferrite - pearlite microstruture, perhaps accounting for its strength even in the light of the stress risers from the cho.
