Gutting knife for whitetail
Hello guys, I'm looking to purchase a smaller fixed blade knife primarly for feild dressing whitetail deer. I was thinking along the lines of a 3"-3 1/2" blade. I am willing to spend a maximum of $250. I would like a knife that is high quality that I can have for a long time. I'm open as to the blade shape and steel, although I do have a preference towards a droppoint blade. Any and all suggestions would be appreciated.
Thanks!
I have used this for many deer. D2 steel. I have dressed two deer without sharpening and still razor sharp. Just right for squirrels and rabbits also.
I've gutted deer with everything from a Camillus pilots survival knife, to an Uncle Henry stockman. But most of my deer were gutted with the Buck 110 that I bought about 50 years ago. I know you said fixed blade, but maybe consider a Buck 110 LT. They're lightweight, stainless steel, don't take up much room, and you can just hose them off when you're done. They only cost about $40, made in the USA, and have a lifetime warranty. Just another option.
Might want to do a little reading about Buck Knives verses Dozier Knives.
I’m sure knarfeng knarfeng has done plenty of reading on both.
I’d recommend a Buck 102 Pro.
Never used a Dozier. Too pricey.
I have used a Buck 105 in 440C. But I haven't hunted since the 80's. Buck Knives has specialized in hunting knives throughout their history. And the OP has a yen for drop points.
P petersonfishon can you tell us a bit about yourself and your specific needs? Here's a few things to think about:
- Will you be field dressing more than one deer at a time?
- Will you use the same knife to quarter and butcher the deer?
- Do you want a fixed or folder? Or are you open to both?
- Do you value high edge retention or ease of sharpening?
- Are you comfortable with quickly sharpening freehand in the field, or are you more comfortable with a guided sharpening system?
- Are you comfortable with the maintenance that may be required for carbon or tool steels (which will stain and rust) or do you want something as low maintenance as possible?
- Do you need something minimalistic and ultralight, or does weight not matter?
As others have mentioned, there's a LOT of options ranging from slipjoint folders that will work in a pinch to custom, purpose-built fixed blades, at every price point. There are also lots of makers here on the forums that can build you something spectacular for your price point.
Have a look here.......Definitely find something you will love....👍
Most of the time I would only be useing it for one deer At a time.
I have a dedicated skining knife and usually use a deboneing knife for quarteing, so I'm looking for something just specific to gutting
I would honestly rather something that is a bit more low maintenance rather than a carbon steel.
As far as sharpening, I'm ok with feild touchups, but I'm more comfortable doing my serious sharpening with a guided system
I would prefer easy to sharpen over amazing edge retention.
Weight isn't really an issue, but I am looking for something relatively small and simplistic.
I would much prefer a fixed blade.
Thank you for the great Q's.
I posted previously about Volunteer Knife thinking of a great do-all deer knife. If all you want is a gutting knife, the Model 3 would be perfect.
For much less money, and still do a great job- Cold Steel Mini Pendleton in AUS10 is a great little knife. The Master Hunter is probably one of the better designs for a field knife and I have gutted/dressed many critters with one.
Boy-howdy, you're in luck. Based on your answers, there are hundreds of great options readily available from manufacturers. There are also unlimited options with custom makers.
A few you may want to look up are:
- the Alpha Wolf and Classic Hunter from Knives of Alaska. Granted, they are D2 but I never had any issues with rust. They also offer Magnacut blades now.
- Buck Paklite series in both 420HC and S35VN.
- Spyderco Mule Team can be found in various steels for about $150, including a sheath and handed scales.
- Cold Steel Pendleton and Mini Pendleton.
As for custom makers, David Mary David Mary , navman navman , and Horsewright Horsewright come to mind in your size and price range.
I tend to like larger knives (4-6") for field dressing and quartering deer, but these two are in your size bracket and are up to the task:
Carothers EDC 1.2
Bird n' Shark by David Mary
Happy Hunting!
