- Feb 19, 2007
'Work hardening' is also called 'cold working' , heat will tend to soften it [as in stress relieve and anneal..
Yep, thats true. But the major factor of these kinds of steel is that the cold rolling itself transforms a percentage of the material to martensite. So basically, the higher reduction in coldrolling (without intermidiate heat relaxation) the higher the theoretical hardness. Apart from that the H1 could also have some precipitation hardening effects which is iduced by heat treat. but only the anealing step, not the full H/T cycle.
If H1 increases hardness by grinding, as such, I would be VERY surprised. Only if it's a dry grinding which induces heat high enough for an anealing effect to start the precipitation hardening. If it's a wet grinding without heat I dont believe that the grinding contributes to the hardness. Only heat and cold deformation affects steel. Grinding is not cold deformation.
The hardness of H-1 is somewhat of a mystery to me, anything over 57 HRC for a PH hardened steel (or a spring steel) is higher than I have ever seen, thats why martensitic steels are used for knives.
