- Jun 23, 2006
I've owned 2 PE Salt I's and both of them did get harder at the edge after some heavy use and sharpening.
I've had to do hardness tests on various metals with a UCI-type harness tester and work hardening is a fairly relevant issue on a lot of metals. The prep (including grinding) required to actually do the test can harden the surface and skew the results. Anyway, in a knife steel, work hardening can be your friend.
:thumbup:
ETA: Forgot to mention I didn't try to check the actual hardness of my blades, but it was an OBVIOUS performance increase. I was using them to cut a lot of cardboard and insulation on a daily basis, so as they got harder, it was very plain that the edge was lasting quite a bit longer.
