had temperance lost it, was best knive ever, whats another option
mjb2007
BANNED
Ive had the green temperance plain balde. By far the strongest knife and most durable blade, lock, everysthing i have ever owned. But i recently lost it. Is the manix 83mm just as good, if not what is and maybe smaller or cheaper
The 83mm manix is a solid tank of a knife. I personally have never held a folder aside from the large striders that "felt" as heavy duty, and I'd sooner bet my money on a spyderco lockback than any framelock.
IT was the the lil temperance, green, amazing, priceless knife . youd think it was a fixed blade.
My condolences on your loss:(
I'd second the Mini Manix, or if you'd prefer a comp lock, the Para-Military might be an option.
I had one of those Lil' Temps. Mine was green with 440V steel. I have also had a Mini-Manix. Heads up, I think the Mini-Manix is a better knife by a little bit. It doesn't blow the Lil'Temp out of the water but I think the design is more refined. It takes up much less room in the pocket and carrys better than the LT. It has a better lock than the LT that is ambi friendly. It carries easier than the LT esp. in tip down carry. It has a better clip than the LT. The LT looked better and was finish just a bit nicer but not enough to outweight all the benefits of the Mini-Manix. When you figuire that the LT now goes for close to $200 and the Mini can be had for about half that, it is a no brainer. There is simply no way the LT is worth twice what a Mini Manix is worth.
