nozh2002
BANNED
- Jun 9, 2003
I was asked from my Russian friend about HT of ATS34.
I run google and found two confusing quotes:
1. Heat the metal quickly to 1975F (1079C), leave it at that temperature for 40 minutes. Quench with liquid argon to -120F (-84C). Straighten the blade if necessary. Freeze the blade to -220F (-140C) and leave it at that temperature for eight hours. Heat the blade to 950F (510C) and maintain it at that temperature for two hours, allow it to cool quickly to room temperature, then reheat quickly to 950F (510C) again, maintain at that temperature for two hours again, and cool slowly to room temperature. This will result in a hardness of 59-60 Rockwell.
http://www.balisongcollector.com/rockwell.html
2. Heat to 1975 degrees F and soak for 40 minutes. Quench in Argon or rapid quench in air, straighten as necessary before freezing to 120 degrees F, than freeze to below 220 degrees F for 6 - 8 hours to transform retained austerities. Double temper at 950 degrees F, 2 hours for each temper. This gives a final Rc of 59 - 60.
http://ajh-knives.com/metals.html
So my question is quenching suppose to be in Argon or liquid Argon and to 120F or -120F.
I guess second is correct only it should be -220F in liquid nitrogen?
Thanks, Vassili.
Thanks, Vassili.
