Half a dozen Spydercos plus a Knafs Co & Boker
SaintZe
Feedback: +24 / =0 / -0
additional photos
Happy to do bundle deals. Looking for a sun/moon chaparral, UKPK or similar size knife in magnacut, maybe a dragonfly in something nicer than S30v.
From the top:
$65: Jacked Up Boker Plus Exskelibur: Decade edition scales/liners, standard S35VN blade. Stripped screws on the middle stud, liner lock is all kinds of bent and I sanded out a relief cutout on the o ther side make it easier to disengage said liner lock. I would not baton with this thing but it hasn't failed under use though it will flex. Carbon fiber scales are in great shape, action is solid. Beautiful high hollow grind that's genuinely thin behind the edge. Great project knife or the cheapest way to experience the approximate ergos of a Burger LEXK.
$80 Knafs Co Yipper: Only flipped, has box and all accessories plus larger thumbstuds. More Leek than 940 size. Blade favors the left side, disassembled to check fit but never bothered to try and fix it.
$130: Spyderco Bradley Advocate 2nd. Pre CQI. Stronger detent than stock, functions great and I've flipped it an awful lot with no issues but the washers don't have too many disassemblies left. I'll include a couple of copper washers of appropriate size that just need to be sanded down to the right thickness. Flats touched up with 2k grit sandpaper to take off corrosion. No box but will include the original pocket clip.
$125: Spyderco SpyOpera: Light user, edge needs a touchup, couple faint scratches on the blade CQI version with ambi clip cutouts. Really beautiful chamfering work on the spine/backlock. Includes box
$80: Spyderco Lil Matriarch: User, mostly rope and plant matter. Serrations touched up but not worn down, scratches various bits polished w/2k grit sandpaper to remove corrosion spots. Includes box.
SOLD $130: Spyderco Kapara: A couple scratches around the spyderhole on the right, otherwise in excellent shape. Has box.
$140: Spyderco Caribbean: User, plenty of scratches, strengthened the detent a little bit. One of Spyderco's best designs IMO I just do not need a knife this large. Has box.
$120: Spyderco Waterway 2nd: Used a couple of times, naturally for LC200n has some scratching as a result.
$140: Rainer Knives Basecamp: One big scratch on the right side of the blade, otherwise looks great. Huge fan of this one but I haven't used it in years.
