- Jan 3, 2013
Accusations have been made that the Sheffield cutlers were slow to adopt the round tang as they foresaw it would ultimately lead to them making less knives!![]()
Sounds like a bunch of smart fellers.
As has been mentioned if a knife has a strong spring they provide some measure of safety.
I've never been able to figure out the logic in that argument. I have all sorts of soft closing traditional knives, including a Buck 303 which I carried and used every day for well over a decade for all sorts of nasty cutting chores. In well over 50 years of using traditional knives I have NEVER had a knife accidentally close on my fingers.
Traditional knives are meant for cutting with the edge, not piercing with the tip. As you cut with the edge, you are pushing the knife open. How is it going to close on you? If you need a piercing cut, you use a sheepsfoot or Wharncliffe blade so that, as you push, you are actually pushing the knife open.
As for half stops, I mostly don't care for them. But the presence of one is not a deal breaker for me.
I've done it several times. It happens when you first get the blade over that first corner and it shifts from wanting to close to wanting to open. If the spring is very strong and the half-stop is very defined there is a sudden change in force. The blade used to be pushing against your thumbnail that's in the nick, and now it's pulling away. What happens is your nail slips out of the nick and you don't have time to react, so you're still pushing with that thumb. The thumb slides up past the blade and the edge catches on your knuckle. My 23 has caught me a couple of times like this, especially when it was new and I wasn't yet accustomed to it's mighty snap.
Finally, the square and flush joint a la Remington is a thing of beauty.
Definitely prefer half stops. Anecdotally I observe that they prevent wear and help the spring retain its snap after years and years. Also possible self-cleaning properties. Finally, the square and flush joint a la Remington is a thing of beauty.
