I think that is the correct name for a tang visible from the top of the knife but which only extends half the depth (top to bottom) of the handle and may or may not run the full length.
Does anyone use scales to build up such a handle? I'm thinking either 3 layers of micarta, 2 as traditional handle scales and a third in the middle under the blade tang 'filling in' the rest of the handle, or 2 layers of thicker material with a rabbet type joint where the tang will fit.
Failing that, is there a reasonable way with minimal power tools (drill press and bits, bench grinder, bandsaw) to notch a block of handle material (probably micarta in this case) for the tang since I don't have access to a mill or router tools? I don't think I'm good enough to do it with a table saw without unnecessarily risking a finger.
Why, you may ask? Well I want more curvature to the handle on a relatively small knife and I don't want to file/grind out wide, expensive ATS34 stock to get it. With 1" stock I can get the blade and a half tang done and still have the handle curve to a nice hand fitting shape. I'm thinking of a small/medium game knife with a Loveless style curved shape but a drop or clipped point blade more like a Knives of Alaska caping knife shape. The curve would require 1.5" stock, but with the half tang 1" stock and a LOT less grinding would work fine.
The reduction of weight in the handle might make for a nice fringe benefit.
What do you guys think? Does it sound like a reasonable combination of features or like something that just won't work out in the end?
