hammocks
I have tried more then a few and they are all not equal. The biggest thing that makes up comfort is the size of the hammock. Is it long enough and wide enough. I like a hammock that is wide enough I can lay diagonally in it.
I just did a video of me setting up my Grand Trunk Double. I added a ridgeline and changed out the suspension to cinch buckles and straps.
[video=youtube;fEp2m7OdPiE]https://www.youtube.com/watch?v=fEp2m7OdPiE[/video]
I just picked up a new Grand Trunk Double in Ripstop Kryptek. I immediately did some quick mods to bring the hammock up to my liking.
I added a structural ridge line from Arrowhead Equipment. I like it because it can be easily removed.
Also a organizer from Arrowhead
I removed the stock suspension (which was just two braided cords) and replaced them with Warbonnet cinch buckles and straps. I have used these before and love how easy they are to adjust.
Also set up the Yukon Outfitters Kindle underquilt
I like the shape, its more like a banana
Cone dog had to bet into the action
Hi Neeman -
Sorry i'm late in reply..... I like my ENO Double Nest, though it is pretty lightweight. That said, it seems strong and easy to set up (so far only in my back yard). I'm confident it will suffice for camping - though possibly less durable (speculation....).
I must admit the comments about using an under quilt are spot on. I noticed even in mild temperatures the significant convective cooling loss. You may have less use for one in your climate (though i suspect you encounter some cold temps), but here in Colorado i can tell an under quilt will be necessary. I am reviewing DIY solutions already.
I hope you were able to get one on sale, but if not there are other equally affordable hammocks available!
35 C right now so warm enough for a hammock!
the main problem will be trees to hang the hammock
Whooooo who! 35C is nothing to take lightly - too hot for this polar bear. I would bet the convective cooling would be a welcome relief from the heat of the day (only to need insulation against the cool of the night).
Were you able to take advantage of the sale? Regardless, there are some very nice hammocks similarly priced and regarded higher than the ENO (though ENO is regarded well enough, but not for continued, heavy-use camping).
I just folded a 64 ft, 2.5" mesh, 5 ft wide monofilament gill net back upon itself 3x. It works fine as a hammock and it can feed you (in most areas) if you know how to set it up. Gill nets are illegal to use almost everywhere, so using one is a life or death sort of deal.
Right, and on the wrong day, you are carrying a poaching tool. Not sure I'd rely on how friendly my local rangers were.
you scare easy. I've never once even met a ranger, much less had them search my gear. i normally carry lots more "iffy" stuff than a mere gill net.
That's up to you. Walk your own walk. I just thought I'd mention it for anyone passing through. As to my attitudes towards breaking laws, my reasons are my own, it won't pay to jump to conclusions.
I know a couple of rangers and they tell me "I've got enough problems". If I dont SEE a violation or have reason to suspect one, I just try to be helpful and then move on with my schedule".
Dream Hammock. For many options and variables including asym, fabric, and layer choices. Warbonnet is also popular, but def check out Dream Hammock.
I worked up a couple of velcro seamed, tyvek bags, which open up and velcro together to form a tarp or tent. Keep the wind off of you and your hammock setup will be much warmer. I detest sleeping on the ground since I went to hammock camping. If you'll just wrap and tie the cordage decently on the tree, very little damage is done. It's not all that hard to find dead (but still solid) or garbage-type trees to hang from. I"m not out there a lot anymore. but if I was, I'd probably not be moving all that much, so few trees would be at-risk, anyway.
And your "hammock" will catch on and entangle everything. There's a reason people quit using net hammocks in the field decades ago.
