The hamon is the junction between the hardened edge ( ha) and the softer body ( ji). The formation of different crystal structures in the hamon and its boundaries is what makes the line white in some cases, and wispy in others. This is the nie and the nioi.
The old term for the structure in the hamon was troosite ( until around the 1970's when everyone but me abandoned the term). It is a mixture of pearlite, martensite, and some mixed structures. The surface of a nihonto blade can be examined by an expert, and the structure of the steel determined by sight. The large wandering martensite crystals ( bright spots = nioi) in the ji tell of spots where the steel hardened on the surface with breaks or thin spots in the clay. The nie shows where the pearlite wanders into the martensite, caused by the ashi. The darker color of the ha shows the full matensitic structure of the exposed steel.The distinct hamon line shows where the martensite and pearlite meet and how much they intermingle. The soft and more dully reflective ji and shinogi ji show the pearlitic structure of the body of the blade. In places where the shingane ( soft iron core) shows through the ji-gane (harder surface steel) the examiner can tell how well the sword was made, and how much it has been re-polished.
The ABS test blade has nothing to do with a real life blade. No one would create such a blade for general use. It is a test to show the ability to create two vastly different conditions in the same blade, and the ability to control them to a specific function ( bend test). No blade should normally be expected to need this function. The Japanese blade is probably the closest to this type of blade condition, however. It was designed to have a hard, tough, and sharp edge; a soft and ductile core; a strong and flexible spine; and the ability to take a severe bend with only edge cracking. The ancient smiths accomplished all this without any metallurgy. They understood the look and feel of the steel. It has only been in the past 50-75 years that any idea of the actual structures has evolved.
In my opinion, differential hardening by clay coating and full quenching is for developing a hamon. Edge quenching is not an acceptable substitute. The better functioning blade is fully hardened and differentially tempered. You won't get the mystical hamon, but you will get a tough blade.
Stacy
