Hamon Clay
If I wanted to create a hamon on a kitchen knife, what would be the easiest/cheapest clay to make/buy? Also what etching solution do you use? The steel is 3/32 and 1/8 1095.
You can get the satinite from the local stove store or maybe block and brick store, Not sure on the block store. I use ferric chloride from Radio Shack diluted with distilled water for etching. I hope some with more experience chime in with more help.
I have used furnace cement thinned to melted ice cream consistency. Bake it on at 350 for an hour prior to HT to make sure it doesn't bubble or fall off.
Sent from my XT1095 using Tapatalk
I have tried furnace cement and it works fine. I tried Do-All made by Durst which I didn't like. The consistency was too gritty or lumpy. It didn't get creamy when thinned. My favorite (not having tried Satanite) is Rutland's Black furnace cement. It thins to a nice creamy consistency and goes on the blade well. Then I let it dry to the touch. When it gets firm enough to handle carefully I put it in the oven. I find a warm heat, about 200˚ for 10-15 minutes works well before austenitizing. Otherwise it puffs up in the heat treat.
I think there is some translation problem with the previous post. Suffice to say that a hamon is primarily decorative in the modern world. A fully hardened blade has the same edge abilities.
Satanite and Rutland's Black cement both work. I far prefer satanite.
Most people put it on way too thick. I get best results by first putting a "wash" of very runny clay (melted milkshake consistency) over the entire blade, and then covering the spine area above the desired hamon with a thin layer of "sour cream" consistency clay. I only put it on about 1/16" thick. Let that dry well before the HT.
Yaki-ire is a big subject, and you need to do some reading on it before you try it. Use the custom search engine in the Stickys to search hamon and yaki-ire.
The etchant is normally FC in a dilution around 15:1. Other etchants are used for getting the finer details on complex hamon. The sanding and polishing methods are very important.
Stacy, have you done interrupt quenched for more activity? I just tried with 1 w2 knife and 1 w2 knife a regular quench. They are tempering now so I have not checked the outcome yet but wondering if you had any experience with it. This is my first time trying it so I have no idea.
Here some use fireplace sealant ................
I tried the furnace cement for a while but Satanite works much better for me.
I use ferric chloride but you can use lemon juice or vinegar. That are slower but I think they help bring out ashi, the white whisky stuff.
