Hamon goop
Charlie Mike
Sober since 1-7-14 (still a Paranoid Nutjob)
I tried some DAP brand fireplace mortar last night and it actually etched into the steel during HT. Since I have to send out for surface grinding, this is no good. What is the proper goop and where do I score some?
CM, I guess the "Go to" stuff for hamons would be a product called Satanite. I bought mine from High Temp Tools. I have also heard that the black Rutland's furnace cement, that you can buy in a caulk tube, works well, and can be had from Ace Hardware, True Value, etc.
Some guys make their own "goop"! With my luck, if I tried making my own, it would put the hamon on the spine instead of the edge!
If you want to go really old school you can do a fine wash of clay over the whole blade and then use a mix of clay, ground charcoal, and ground up straw or hay (as a binder). It works best if you wrap the blade with a spiral of iron wire both to create ashi and to give the cussed stuff something to grab onto.
Are you sure it actually etched into the steel? Isn't it possible that you got scaling/decarb in the bare area and you see the difference between the covered area?
Many of the fireplace mortar compounds are mostly sodium silicate. They leave an etched surface, and can leave a little lip where they stop. Not a big deal, usually.
I use Satanite with good results.
Why are you surface grinding the blade after a hamon HT? That seems counter to the idea and process of developing a hamon.
I'm grinding in the hardened state to prevent warps. I'm hardening unground blades. The temper line still appears.
CM, I have tried a few Hamons (Few being key word) and have had good luck with the Black Rutlands furnace cement.
