I have a problem when it comes time to etch and bring out my hamon in my knives. I use 1095 that I grind, drill, normalize, clay treat and quench in parks and get a really good differential HT out of it. I got on to finish grinding and hand sand down to 2000 grit WD. At this stage I etch in ferric for about 10-15 min and while the blade goes into the etch very smooth and level after hand sanding it comes out with light grooves lengthwise down parts of the bade almost like there is small strips of metal that the etch is more effect to than others. It looks like I stopped hand sanding at 220 in some places, I was wondering if anyone else has had this problem and if so what am I doing wrong?
If it helps this problem seems to be most prevalent in the transition area and in the softer metal, the hardend edge does not get this problem nearly as much if at all.
