- Nov 27, 2013
Your challenges are multi faceted.
Truth is, if you had a good soak on the steel at welding heat and the pieces were quite smooth - like surface ground - you could probably get the first major weld done successfully in a vise with some jaw extensions to press the entire billet at once.
Then - bring it back up to heat with another good soak and do it again.
I'm not kidding you when I say this - if you have nearly perfect surfaces on your billet pieces and you weld that billet together while clamped tightly in a vise, you have a really good start.
Have your forge up to welding heat when you place the billet in.
Soak a good 15 minutes.
That alone may be giving you a weld.
I had thought about doing those a while back. I think I even made a thread about it here but was kind of scoffed at when bringing up smushing the weld together using a vise. Now I feel redeemed.
When using the vise method, would it be a good idea to heat the jaw extensions with a leaf burner or torch? To make it so it wasn’t heat sinking the heat right out of it ruining the weld?
Also, am I right in assuming you mean to use this method after dry welding the perimeter of the billet?
Lastly, when surface grinding the pieces of steel to use in the billet, what grit do you think would be optimal?
As always, thanks for sharing your knowledge Karl. You’re the man.
