"Hand Made" Whaty does that mean to you?
I can tell you for certain that no sane person considers a CNC knife "handmade".
Agreed 100%. When a machine creates the bevels and the fancy fluting on the bevels, and shapes the handle scales and cuts the handle textures, it is doing most of the work that breathes the “soul” into the knife, the work that, without a machine, requires hand-craftsmanship. Anyone with basic hand eye coordination can assemble a knife. Or push a button. That being said, there is definitely an artistry and craftsmanship involved in design, and the use of the tools of design such as CAD programs and CNC. The superior precision of the latter is undeniable. But it’s not hand made. And that’s fine.
As a buyer/user/collector, I don't care if it's "handmade" as per the definition of many purists out there. I just care about the quality of work and the final end product.
Gareth Bull has been making handmade folders for well over a decade, and his process is mind-boggling to the point where his WIP threads have become a guide for many others. Frames, blades, pivots, clips, are all cut, shaped, ground, and polished by hand using mills, cutting discs, grinders/belts, and the process is repeated in batches where multiple knives of a chosen model are virtually identical.
Nathawut has been making folders similarly, and he will make whatever I come up but he uses CAD to render my designs and delivers perfection in a true custom. He grinds the blades, contours the frames and clips, turns the pivots and screws, but he might source standoffs from Steve Kelly, or the damascus from Chad Nichols, it doesn't matter to me as long as it's what I want. I still consider this handmade.
David Mary is another maker who I consider to deliver a handmade product, and even true customs. My design, his work. He'll have sheets of steel waterjetted and heat treated by someone else, and that's perfectly fine. Once the blades come into his possession, the man spends whatever time is needed to grind the blades, fit handle material and countour everything. Using a 3rd party for waterjetting and heat treating blanks is a no-brainer when you're putting out 60 knives in a run of different models. That's working smarter and not harder. The knives I get from him have my choice of handle material, grind, heat treat, and fixtures, all ground and put together by hand. It'd be crazy to work on 50 different knives in a batch with different heat treats and handle materials without farming out some of the work.
What I care about most is quality and attention to detail. Those 3 guys I mentioned above deliver those in loads, in work that I consider to be handmade, albeit to varying degrees loosely based on a modern, purist definition.
Make your own screws or GTFO
Handmade, right?
You may laugh but I know of custom flintlock rifle makers who make their own screws. Some have bored their own barrels by hand using 18th century techniques. That is hand made in every sense of the word, but you pay for the privilege of that work.
Well lay off whatever that sauce is in that bottle then!!!!!!😜
What is it anywho?🤔
Liquid dish soap......as a lube for drilling and tapping. It's far from perfect, but I have it, it's cheap, it's clean, and way better than nothing.
Have to heat treat using hand generated friction, like Mister Miyagi.
