- Aug 9, 2013
I just found out I'm going backpacking in Big Bend on 4/24-4/27 and I want to bust out a couple knives before then so, since I outsource my HT, I need to find a blank that's already hardened.
Here's what I found.
http://usaknifemaker.com/bushcraft-8-5-long-15-thick-ground-elmax-steel-heat-treated.html
What are your thoughts on how to handle* this blade? (*as in putting handles on it)
I like this look with the black micarta bolsters and it seems the blade is pin holes set up for that with the two pin holes up front. Right?
If I were to go with one solid piece on both sides, do you think the two main pin holes are too close together?
Also, How do I work that lanyard hole at the bottom? Do I bring my scales down to that sharp point and have holes drilled through the scales? Leave that piece exposed as some sort of glass-breaker thing? (i'm not real partial to that idea)
Suggestions, please. I know you guys will come through for me- you always do.
